egr removal
Old Apr 13, 2014 | 10:06 AM
92C4M6's Avatar
92C4M6
So installed the headers, mostly was very easy everything came and went in very well. Except I broke a wiring harness for a sensor and idk which one it was, its on the drivers side kinda near the bottom of the block under cylinder 8? Its like a big metal tube with now two pins exposed any idea what it is?
Old Apr 13, 2014 | 10:13 AM
MrWillys's Avatar
MrWillys
Driver side only has cylinders 1.3.5. and 7. under #7 and above the oil filter would be the oil pressure sensor.
Old Apr 13, 2014 | 10:16 AM
92C4M6's Avatar
92C4M6
I meant 7....fail. And thanks
Old Apr 13, 2014 | 04:04 PM
92C4M6's Avatar
92C4M6
Also removed air and egr stuff, my block off plates haven't arrived yet(due in tomorrow) and my tuned chip that's tuned for egr /air removed is due in tomorrow via ups. Problem is now the car under load is struggling to rev and back firing a bit....only code is #26. Didn't thing removing egr and air would effect it. Never has in past but do these sound lime symptoms of removing this stuff
