tachometer
Apr 11, 2014 | 07:44 PM
tachometer
Hi everybody,
I own a 1984 4 plus three Corvette. The tachometer lights up but it says zero. A couple of days ago it was working and now. It just shows a zero. I looked at the pink wire that goes into the distributor. It is connected. any suggestions.
thank you
Apr 11, 2014 | 08:49 PM
Quote:
Originally Posted by
jseremba
Pink is the power to the coil ; white wire on the
TACH terminal is the tacho signal wire
Also check the connection on the white wire to / from the tacho filter
Apr 11, 2014 | 10:22 PM
thank you. I will give it a look
Apr 18, 2014 | 08:51 PM
Cruising
jseremba
Mine had the wire broke right at the filter piece. It was hard to see. You can hook it up direct just to trouble shoot the filter.-T
Apr 20, 2014 | 01:50 PM
kaniyrret
that's what I did. What is the filter for? On my 69 Corvette I thought it was static suppression
Apr 20, 2014 | 03:03 PM
Cruising
jseremba
I m pretty sure that what it's for. Just to filter out any electrical interference.
