EGR Valve sealing ability.
Old Apr 18, 2014 | 03:42 PM
pcolt94's Avatar
pcolt94
Default EGR Valve sealing ability.
Currently chasing a hesitation problem and without going off in a tangent on that at this time I was reading a post recently about a EGR problem which got me thinking. I am not done checking out the fuel system yet but the EGR is quick to do.
Once I got it out I cleaned it up. Suction opens it and there is no diaphragm leaks there. But when I suck on the round stub, it seals but not 100%. I can still pull some slight air thru it. When I connect my vacuum pump to it, it does not hold any pressure at all. I'm not sure is a slight seepage is normal but if it is affecting manifold pressure it could be affecting the FPR regulation.
How tight should the sealing be?
Going to a part store in the next couple days just to look at a new one and see if there is any noticeable difference.
Old Apr 18, 2014 | 05:20 PM
S S0DEN's Avatar
S S0DEN
My EGR would not seal 100% either, it would throw a code on the highway even after I attempted to clean it out and noticed the same thing. I installed a new EGR and cleared the code and I was good to go, ended up eliminating the EGR.
Old Apr 19, 2014 | 03:15 AM
Cliff Harris's Avatar
Cliff Harris
You can unscrew the seat and clean it. See this:
http://tech.corvettecentral.com/2012...egr-diagnosis/
Old Apr 19, 2014 | 09:55 AM
pcolt94's Avatar
pcolt94
Thank you, everything you wanted to know about EGR and more.
I did not know it came apart in that way. I will be driving the car today and see if there is any change from the clean up yesterday.
I read the link quick but when I get some time I will read it more carefully and re-visit the EGR when I'm ready.
Old Apr 19, 2014 | 06:29 PM
pcolt94's Avatar
pcolt94
So I went to the store and checked out a new EGR. Other that it being new, I can't really say I see any difference between the new and my original. The new one did not hold suction and had similar leakage to mine.
I may give my EGR a better cleaning and follow the "link" information, but I don't think at this time my EGR is bad and don’t think I am on the right track for the problem I'm trying to solve.
Old Apr 20, 2014 | 02:34 AM
Cliff Harris
I bought an EGR valve from AutoZone. I tested it on the bench before installing it and it did not hold vacuum. I took it back and bought one from the local Chevy dealer. It did hold vacuum and is now on my car.
I have heard of other people who had problems with aftermarket EGR valves. AC Delco only for me.
Old Apr 20, 2014 | 02:39 PM
tunedport85inject's Avatar
tunedport85inject
block off plate and rtv...done
Old Apr 20, 2014 | 03:42 PM
pcolt94's Avatar
pcolt94
Had the EGR off again, cleaned it best I could. Could not get it apart to do what I wanted to do and did not want to ruin it with brute force. So for now it's back on the car. Since I'm into all this stuff now, I did check out the vacuum line to it and to the EGR. Put a vacuum on it, activated the solenoid with a Tech1 and all is working as it should.
After reading additional information on the internet the thought did occur to me. What will it do for me. Are there any disadvantages?
I also thought of making the plate at least for testing purposes to see if it has any relationship to my original problem.
I would put a new EGR in if I knew for sure it was fixing my problem.
To EGR Valve sealing ability.
