85 4+3 engine removal
Old Apr 18, 2014 | 09:39 AM
jmrl98's Avatar
jmrl98
Default 85 4+3 engine removal
If anyone has removed their engine from their 85 4+3, did you also drop the trans or just support it? Did you have to remove the oil pan? Tx
Old Apr 18, 2014 | 03:30 PM
kaniyrret's Avatar
kaniyrret
Cruising
I pulled it all together from my 88
Old Apr 18, 2014 | 07:23 PM
jv9999's Avatar
jv9999
I dropped the trans first and then pulled the engine. If you leave the hood on, there's not enough room to pull them together.
Old Apr 18, 2014 | 08:37 PM
kaniyrret's Avatar
kaniyrret
Cruising
I actually went in and out with the hood still on. Although I must admit the replacement took some effort. Mine was the 4+3 tranny, yours?
Old Apr 18, 2014 | 08:43 PM
Bob1985z51's Avatar
Bob1985z51
I pulled tranny and motor on my 85 with a zf swap hood was still on, actually much easier when it comes to re installing it. You don't have to hassle alining them under the car and getting it out was a peice of cake just make sure everything is disconnected.
Old Apr 18, 2014 | 10:28 PM
jv9999's Avatar
jv9999
I'm really surprised you guys had the room with the trans on and the hood on. Even without the trans it was a bit tricky to get mine back in without the trans (4+3). Putting the trans on later wasn't a big deal (just need to make sure you aligned the clutch right).
Old Apr 19, 2014 | 08:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I pulled the engine with the bell housing and left the trans in place.
To 85 4+3 engine removal
