need help with Vortec engine
Old Jul 18, 2002 | 10:46 PM
rguy's Avatar
rguy
Default need help with Vortec engine
I'm considering to purchase a '96 Vortec 350 V8 engine and need to know how I can tell it's a Vortec and not just a regular Chevy V8. I know those engines have roller cams and I think the heads use self aligning rockers. Is there anything else?
Thanks.
Rob
Old Jul 19, 2002 | 12:18 AM
18carfan's Avatar
18carfan
Cruise-In II Veteran
Default Re: need help with Vortec engine (rguy)
Easiest clue is the intake bolt pattern. Only 4 on each side - two up front and two in rear - for a total of 8 instead of 12 like an older non-Vortec V-8. If you want to know exactly what it is, get the engine code stamped in the front of the RH cyl deck and have it crossed over. -Jeff
Old Jul 19, 2002 | 12:46 AM
rguy's Avatar
rguy
Default Re: need help with Vortec engine (18carfan)
is there a 305 Vortec engine or are all of them 350s?
Old Jul 19, 2002 | 11:06 AM
18carfan's Avatar
18carfan
Yes, there was a Vortec 305 too.
To need help with Vortec engine
