crank with no threads
Old Apr 26, 2014 | 06:30 PM
mizzys 86's Avatar
mizzys 86
Default crank with no threads
have early 350 in my 86 it has no threads on crank How do you put balancer on while motor in car..I can put in intill it stops but it wiggles . I put new key in help
Old Apr 26, 2014 | 06:51 PM
cohocarl's Avatar
cohocarl
The balancer is an interference fit on the crankshaft snout, so it shouldn't wiggle.
Most SBC cranks did not have a threaded bolt on the end of the crankshaft snout until around the late 60's if I recall correctly. Does yours not have threads in it, or has a bolt been broken off in there? Might be able to see with a mirror & flashlight.
If it is an early crank, I am not sure if they took a different balancer, or how they were pressed on. Anyone?
Old Apr 26, 2014 | 07:34 PM
mizzys 86's Avatar
mizzys 86
Will drilling and tapping it be the answer.. I cant imange how it came loose if it was pressed on... there is no broken bolt
Old Apr 26, 2014 | 09:54 PM
jv9999's Avatar
jv9999
I had a mid 60's 327 crank with no threads a while back. I successfully drilled and tapped it with the engine in the car. I seem to recall there was a forged opening that held the drill bit true.
Old Apr 27, 2014 | 04:12 AM
gerardvg's Avatar
gerardvg
Hi
Yes drill and tap the crankshaft, also use the correct tool to install the ballancer, It has a thread that screws into the crankshaft and has a wide nut to tighten the ballancer till its fully seated.
Then remove the threaded shaft with two nuts tightened.
I always clean the crankshaft and put a little oil on the crankshaft snout and ballancer. You can get away with a couple of longer bolts to start the ballancer onto the crankshaft, then when it is almost home use the correct length bolt and torque it. Do not overdo it if you think its not going any further and is jammed remove the ballancer put oil on check the crankshaft for any burs (going over a little with emery paper should make it fit easily) emery paper is like sandpaper but on a cloth.
If you are not careful you will end up having to tap an even bigger thread.
Old Apr 27, 2014 | 09:31 AM
mizzys 86's Avatar
mizzys 86
Originally Posted by gerardvg
Hi
Old Apr 27, 2014 | 09:55 AM
ex-x-fire's Avatar
ex-x-fire
Guys have put the balancers in boiling hot water & then slipped them right on.
Old Apr 27, 2014 | 02:16 PM
mizzys 86's Avatar
mizzys 86
mine slides on easy and with key in I can wiggle off w/o using puller upon further examination it looks the bolt broke off . that has to be the only way to stay on ...it can not be fitted otherwise I couldn't remove so easy..tpia have to get 90 deg drill and use easy out hopefully it works... car run fine before this.
Old Apr 27, 2014 | 03:36 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If it were ME....I'd weld on the bolt and extract it before I started in w/the drill.
To crank with no threads
