Broken teeth
Old Apr 26, 2014 | 07:30 PM
383vett's Avatar
383vett
Default Broken teeth
I mentioned last week that my rearend got crunchy during a 3rd round race last week. Got around to removing the cover and as I thought, I have broken ring teeth. (Funny coming from a dentist). I had been using the Richmond street gears in my 12 bolt. Time to switch to their Pro series.
Old Apr 26, 2014 | 07:35 PM
don hall's Avatar
don hall
And I feel guilty when I scrape my air dam..........
Old Apr 26, 2014 | 08:09 PM
John A. Marker's Avatar
John A. Marker
You have a lot of teeth...just not where they are supposed to me to make things turn.
Yes, time to upgrade.
Old Apr 26, 2014 | 08:20 PM
WW7's Avatar
WW7
To Much Power........WW
Old Apr 26, 2014 | 08:21 PM
cohocarl's Avatar
cohocarl
Na...you just forgot to use a bottle of this.
Old Apr 26, 2014 | 11:44 PM
383vett's Avatar
383vett
Do they market a special additive for spools?
Old Apr 27, 2014 | 03:46 AM
gerardvg's Avatar
gerardvg
I agree too much power for the Richmond gears,Yes time upgrade but what is bullet proof with the h/p you are putting through the gears?.
With previous cars i have found out not even the ford 9 inch solid axle rear will last long with drag slicks and a mountain of horsepower.
You will need a fat wallet and a friend in high places who can help you spend the money to find the right combination that will last.
Old Apr 27, 2014 | 07:41 AM
WW7's Avatar
WW7
Cryogenic processing for the gears......WW.
Old Apr 27, 2014 | 09:07 AM
MrWillys's Avatar
MrWillys
That is weird looking gear oil? Almost like it's seen water intrusion.
Old Apr 27, 2014 | 09:46 AM
WVZR-1's Avatar
WVZR-1
I'm quite surprised you weren't already running the high nickel gear set. How frequently do you actually pull the cover and check the gears?
Old Apr 27, 2014 | 11:32 AM
Churchkey's Avatar
Churchkey
Suggestion: Drill & tap the case for a ring gear deflection bolt. .001 or .002 clearance bolt end to ring gear. Or fabricate a brass shoe, slip over the bolt & adjust to continually contact the ring gear.
No suggestions for pinion side deflection or ring gear ride up with your design rear. A 9" with 3rd pinion bearing is required.
Good luck.
Old Apr 27, 2014 | 12:27 PM
383vett's Avatar
383vett
Will you be my Sugar Daddy?
Good thought but gotta go racing.
That's Redline Shockproof gear oil. Looks like Pepto Bismo.
I'm going to start with the Pro Gearset now. I've been getting around 700 runs using the street gear which according to my diff guy and Richmond is a lot for any type of gear. This time I only had 400 so it's time for a change. I change the fluid 1/year but don't open the cover.
Good luck.
Thanks Church, I'll talk to my diff guy about that this week.
Old Apr 27, 2014 | 03:24 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Willie, you can always cap the teeth.
To Broken teeth
