Time for the drag strip!
So, I'm headed to the drag strip soon, either next week or the week after to see what she'll run.
I'm targeting 13:1 WOT AFR, with currently 35* total timing.
While I'm at the drag strip I want to try a few variables.
First, I want to get the launch down using the two step rev limiter in my MSD ignition box. What RPM should I launch at first so I can fine tune the launch RPM?
Secondly, what is the safest AFR I should target at WOT?
Thirdly, if you take a look at my timing table below, where are some places that I should add timing, and how much advance can I have?
Thanks!
I would start out at 12.5 to be safe. You won't gain that much hp being close to the edge. Keep it cool and your motor will last a long time.
work you have recently done, we don't need to hear you destroyed the engine. Nice smooth runs..... good luck!
I suggest you take 'er out onto the highway and do a few WOT runs up through the 1-2 shift point before the strip. This will allow you to gather enough data on A/F & timing before flailing on 'er at the strip.
If your strip has a scale let us know trap speed & launch weight so we can calculate CHP for you.
And pls Daniel, take it easy out there! If you are unsure whether or not your engine and tune are working 100% like they should, dont use two step! If these are your first passes on the strip with the new engine, there's no way you will need to launch with 2-step.
Only time I can think that you'd even consider using one at your power level would be for bracket racing as it would help make you more consistent. But to ME, a two step w/an auto, you set the two step, you launch and the car shifts for you....what are you doing as a driver? Not much reward in that, IMO, but like I said, it's a personal choice.
For your first trip after mods, if I were you, My goals would be the following:
1. Get the car down the track w/conservative driving a few times to confirm soundness and safety -no leaks, good handling etc.
2. Ensure that it's running right; AF ratio, oil pressure, temps, etc.
3. Lastly, I'd want a good TRAP SPEED.
For a first trip, i wouldn't be concerned with launching, wicked 60' times, basement ET's...I'd just want to make sure it's all working right, and I'd want a good trap speed so I'd know horse power and how the engine is working.
I've never raced on the track before, so how long should I expect between each of my runs? I'm going on a test and tune night by the way.
On the timing it looks Ok to me except the 208 load range in my opinion is too aggressive. I would leave the 22 degrees until 2000 RPM and then ramp from 22 degrees to 35 degrees by 3000 RPM.
All ^that^ is pretty advanced driving technique, IMO. Again, I wouldn't recommend going to max effort runs here. I'd just roll out of the box like any semi aggressive street start, floor it, and run it though the gears to get baselines, car assessment, and trap speeds.
As for times between runs? As long as the car is "checking out O.K.", I'd cycle as fast as possible to get the most runs in w/the car. Cycle times TOTALLY depend on the track and how well it's run. Our track here in SLC is a **** show so sometimes it's 3 hours/run.
At New England Dragway/Epping NH, though, I used to find some nights were I could comeback and drive right into the burn out box, make another run and repeat. More runs will prove durability, consistent running and get you some practice.
