crank pulley on 94 help
Old Apr 30, 2014 | 09:00 PM
joepa94's Avatar
joepa94
Cruising
Default crank pulley on 94 help
I'm replacing my water pump and going for the opti spark, I looked at the form about taking the crank pulley off, I tried wedging it( so it wouldn't move) to break the blots loose and the pulley and cranked moved inch or so and then back, am I out of timing on the motor now or fine and how to I get this dam thing off to remove the opti spark, HELP!
