Headlight motor question
Old May 8, 2014 | 03:45 PM
c4tonezone's Avatar
c4tonezone
Default Headlight motor question
Hello to all of the c4 brothers and sisters
hoping someone can help with my passenger side stuck headlight motor. Checked ground, contacts, fusible links, and found nothing out of the norm. The headlight motor stuck open a few time before going dead.
I have changed gears before , so i know what a spinning motor sounds like and its not the gears.
Its like there is no power getting to the motor as it make no noise at all.
Although i believe i've checked most of the common areas, am i missing are possible area of interest to check for a short or a missing ground?
I am almost tempted to connect the headlight motor direct to the battery to see if that sparks some movement.
Any suggestions will be greatly appreciated.
Thanks in advance.
Old May 8, 2014 | 03:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Seems to be the time of year for this; mine went out a few days ago...
What year Vette??
Old May 10, 2014 | 06:15 PM
c4tonezone's Avatar
c4tonezone
Originally Posted by 65z01
seems to be the time of year for this; mine went out a few days ago...
What year vette??
1990
Old May 10, 2014 | 08:09 PM
hooked073's Avatar
hooked073
did you try to lower or raise it manually? If it moves manually I would disconnect the motor and put 12 volts to 1 term and another to the 2nd term and see what happens. one way the headlight should go up switch the wires and the headlight will go the oppsite direction
Old May 10, 2014 | 09:45 PM
DUB's Avatar
DUB
I think that what he meant to write is that when you disconnect the 2 wires for the headlight motor...you apply 12 VOLTS to one terminal...and GROUND to the other terminal.
If the motor operates...then switch the way you had the wires connected and it should operate in the other direction.
The control unit in front of your drivers front tire controls the headlight motors.
DUB
Old May 10, 2014 | 09:54 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
disconnect the motor and do an ohm check on the motor connector, if you get infinity you need a new motor. You could take the motor apart and check the brushes and commutator. If you get a ohm reading then you need to make sure you have the ground and 12v feeds to the module.. If the motor appears good, the ground is at the module and the 4 12v feeds are at the module, and the motor doesn't work, you would appear to need a new module.. (3 with the switch off, the 4th with switch on)
[IMG][/IMG]
To Headlight motor question
