As far as the power loss is concerned it all depends upon the combination of parts and how it was dynoed. Were the engine dyno numbers gross or net, I assume gross. The factory numbers are net. My BBC made a dyno verified 774 HP at the crank and made 636 at the wheels through an auto and 9 inch rear end.
A rough number that most people use is .85 for a manual and .80 for an auto. This just gets you an approximation.
That is an EXCELLENT point, that I hadn't considered at all. If the engine was tested on a stand, no exhaust, no accessories...and I'd bet it was, then that is gross. And there will be a significant power loss when installed.
Still, I thought that heard something break up on the top end, in that vid.
I think the engine was dynoed with no accessories and just headers. The more I think about, I must be losing spark and that is why it goes rich and the end of the pull.
Sweet, would like to have an engine like than in my autocross car!
I couple of observations:
-At the end of the run the engine does not go rich, it actually ends up near where it should be at around 12.5 to 1 AFR. It is actually lean before that with reading near 15 to 1 AFR. I would show this graph to TPIS and see if they can richen it up down low.
-The miss you encounter is probably valve float after 6250 RPM, this is way after your peak power and I would consider shifting earlier like 6100 RPM or changing your valve springs out for different set to try and control the valve float. In my opinion you are reving it too high, the power peak has occurred at 5500 RPM and the engine is on the backside of the curve by 6000 RPM.
-If an engine goes into miss on the dyno you will see your AFR go lean not rich. The O2 sensor is looking for unburned oxygen in the exhaust and a miss will dump all kinds of oxygen in the exhaust showing a lean condition if there is a miss. Looking at your dyno curve I see it going slightly richer which tells me you are not missing but you may be having valve float issues.
>350 rwtq from 2500?
"Mini rams don't make any low end tq"
If you were losing spark, would that show as lean? Lack of combustion = oxygen in exhaust stream? IDK...haven't test that one before....
>350 rwtq from 2500? "Mini rams don't make any low end tq" If you were losing spark, would that show as lean? Lack of combustion = oxygen in exhaust stream? IDK...haven't test that one before....
If I was losing spark wouldn't it go rich because it's not burning the fuel?
That too was my wondering.
...or changing your valve springs out for different set to try and control the valve float.
Also, Ti retainers will reduce controlled mass and allow the springs to better control valve action.
The theory on drag racing I've read recommends to maximize the "area under the HP curve" for optimum 1/4 mile results.
This means shifting above peak HP in order to be higher up on the power curve after the up-shift.
Nice numbers! As far as the power loss is concerned it all depends upon the combination of parts and how it was dynoed. Were the engine dyno numbers gross or net, I assume gross. The factory numbers are net. My BBC made a dyno verified 774 HP at the crank and made 636 at the wheels through an auto and 9 inch rear end. A rough number that most people use is .85 for a manual and .80 for an auto. This just gets you an approximation.
The numbers are gross. I did not know that the manufactures were net. The guy at TPIS said it is common to have a 100hp loss. It is all coming together I think. The motor dynoed at 472tq, and I had 395 at the rear wheelS I am really happy with that. It looks like I just need to shift earlier. Now it is time for the 1/4 mile.
Yes, when I had my car dyno tuned at TPIS, they told me 100hp loss from the engine as well, which like Tom said, I thought was too much power loss in the drive train to what I have seen, but they explained on the engine dyno, we talking no accessories/headers and no exhaust, so yea, GROSS; not NET.....still it is making good power despite the high RPM issue (that I also noticed); sweet!
Here is the machine they used on my car AT TPIS; SUMMER OF 2012: They take the wheels off and put a load on the wheel hubs at different RPMS; not just go WOT.....I think it shows lower power numbers similar to a Mustang dyno vs. a DynoJet machine like the one at Pur Performance where you went.
this is hard to read I know, but this what TPIS hands you.....this is after the tune.....
Here is what I ended with; the 85 computer was taken to task; the best Jim could pull from it after several different pulls. I asked Jim at TPIS to shoot some video and he said he would while we were out, but that never happened.......Oh well........great guys though!
What you have read is correct but to figure out where you should shift you need to determine the largest area under the curve. To do that you need to figure out your gear splits and determine if you shift at 6250 where will the next gear pick up (4200, 4600, 5000?) Once you know the split you can determine your ideal shift points from the dyno graph. In this case you can see that the power holds nicely to around 6200 and then it gets unstable (Valve float or ??) so I would shift by 6200 no matter what.
Really like the white paint and black wheels, nice! TPIS engine dyno numbers in all the articles I have read are always a little high, you didn't lose 100 hp in drive train loss. Case in point;http://www.gmhightechperformance.com..._motor_part_2/ A stock LT1 motor instead of making rated 300 hp made 340 on their dyno.
still pretty stout numbers! Just goes to show.....your bigger cube motor puts down more beans than my 355....across the board......mostly TPIS parts and TPIS tune......some here like smaller stroke engines that rev to 7 but make much less power overall
