proper thermostat
Old May 15, 2014 | 08:47 AM
BishShip3's Avatar
BishShip3
Cruising
Default proper thermostat
New member and corvette owner. What would be the right thermostat for a 87 stock L98
Old May 15, 2014 | 09:51 AM
John A. Marker's Avatar
John A. Marker
I believe that stock is 190, but most of use use a 160 to try and keep these beasts cool.
Old May 15, 2014 | 11:21 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
I bet most of us do not use 160
Old May 15, 2014 | 11:44 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
The correct or factory thermosat is a 195 degree. It's completely normal for it to run at 200 to 228 degrees.
Old May 15, 2014 | 12:04 PM
Joe C's Avatar
Joe C
dropped in a 180° stat in my 90.
Old May 15, 2014 | 12:30 PM
cormorant71's Avatar
cormorant71
I use a 180, but the key to cooling is the fan switch. Replace the factory switch. located between the first 2 cylinders on the drivers side of the block. with a 195. this combination keeps the temp very stable.
Old May 15, 2014 | 04:19 PM
Joe C's Avatar
Joe C
you lost me here - what switch? located between the first 2 cylinders on the drivers side - ??? I thought the coolant temp switch was located on the front of the intake manifold. we are talking an L98 motor, right?
Old May 15, 2014 | 05:09 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed the ECM temp indicator is in the front of the intake base; the sensor between #6 & #8 is for the temp readout on the dash.
The main fan can be controlled on/off at lower temps by either reprograming the ECM or installing a manual fan switch.
I've been running a 160deg F T-stat in my '88s for 14yrs with great results. For city traffic I simply unplug the small connector in the A/C pressure line to run the main fan all the time. On the highway, forward speed creates enough air flow.
Old May 15, 2014 | 06:05 PM
cormorant71
yes, sorry. little confused. on the 2 parts. but here is the part from ecklers that i used.
http://www.ecklerscorvette.com/corve...1984-1995.html
Old May 15, 2014 | 06:55 PM
65Z01's Avatar
65Z01
If his '87 does not have the booster fan option there is a plug between #1 & #3 spark plugs into the coolant jacket that can be removed and a low temp switch installed.
From there it is a simple matter to run a wire to the ECM input to the main fan relay located below the master cylinder on the inner fender well.
BTTB's Avatar
BTTB
Default thermostat
i personally used a 180---a 195 is supposed to help atomize the fuel better--i just didnt feel comfortably with 195 as most thermostats will run 5 to 10 degrees higher than what they are rated for.---for quality you cant beat( robert shaw brand). advance auto carries them under a different brand name.
Old May 15, 2014 | 07:14 PM
playsdixie's Avatar
playsdixie
I use 160 with manual switches for both fans on my z51 85 hardly see 190 in traffic in S Florida.....
Old May 15, 2014 | 11:42 PM
vader86's Avatar
vader86
Stock is 195F. You should notice the coolant temp run to this temp in the morning or from cold, and then pause there. It may equilibrate with the oil before going much further.
Old May 16, 2014 | 08:57 AM
BishShip3's Avatar
BishShip3
Cruising
Thank you all for the input. I'm sure I'll be asking other questions in the future. Great to finally be a member of the Vette Family
Old May 17, 2014 | 12:53 AM
Cliff Harris's Avatar
Cliff Harris
I have an AC Delco thermostat in my car. It consistently runs at about 180° on cold days, so I thought it was a 180°. I recently took it out and it is definitely marked 195° (which is what I intended to put in there).
If your cooling system runs at more than 200° putting in a lower temperature thermostat will not change that. You need to change the radiator and/or cooling fan(s) (or when they come on) to get the temperature down.
To proper thermostat
