Low Coolant Light??
Old Jun 10, 2014 | 07:51 PM
Corvette503's Avatar
Corvette503
Default Low Coolant Light??
Hey Guys..
Not sure why, but I just took my 1989 out of storage to find that the coolant light came on after driving it for a mile or so. Lifted the hood to inspect for leaks, and there was nothing. Recovery tank is at the "Full" line. The light eventually went out, but came on again. After another 20 minutes of driving, the light went off. Engine temp remained between 180-182 degrees.
Does anyone have an idea what could be the cause of this?
I appreciate your thoughts.
Old Jun 10, 2014 | 11:27 PM
GKK's Avatar
GKK
Is the radiator level full?...
Old Jun 10, 2014 | 11:31 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
May have had some air in the system. As GKK said check the level after it cools off.
Old Jun 11, 2014 | 12:16 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Consider a good burp (purge) soon.
Old Jun 11, 2014 | 02:50 AM
Cliff Harris's Avatar
Cliff Harris
You might have a bad radiator cap. Sometimes they will release the coolant into the overflow tank but not allow the system to suck the coolant back in when it cools off.
Sometimes you can get a subtle coolant leak somewhere such that the water evaporates without leaving a puddle under the car. I just replaced a cracked thermostat housing that did that. I also had a leak in the steam tube hose that dripped water on the frame but didn't make a puddle under the car.
Old Jun 11, 2014 | 05:40 AM
Corvette503
Good recommendations..
I will check the radiator level, cap/air in system, and steam tube.
Thanks again for your feedback!
Old Jun 11, 2014 | 05:51 AM
hcbph's Avatar
hcbph
Default Low coolant
I had this happen a couple of times on my 86. First was when driving it home after the purchase. Punched the accelerator coming out of a little town and it went out then came back a couple of hundred miles later. After cooling down, checked the radiator etc, found nothing. It went on and off on it's own a few times later, each time nothing found wrong.
Finally located the sensor (passenger side of the radiator a couple of inches lower) and cleaned the electrical connections and have not had a problem since. Hopefully that was my issue as it seems to now stay out.
Old Jun 11, 2014 | 07:12 AM
AirForceOne!'s Avatar
AirForceOne!
This was the problem with my 90, bad radiator cap! Get a good one from the dealer, not a cheap one from your auto parts store! I think I got one for $14.
Old Jun 11, 2014 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Try packing the cooling system.
Loosen rad cap and get motor to operating temp so stat is open.
Hold rpm at 2000, remove cap and add coolant until full
Replace rad cap then shut motor off.
Old Jun 11, 2014 | 03:51 PM
don hall's Avatar
don hall
Originally Posted by Corvette503
.....Recovery tank is at the "Full" line. .......
The sensor is located in the radiator, not the recovery tank. Check the rad level when 'cold'.
If the recovery tank is 'full', and the rad level is 'low' when 'cold', a siphon is not occurring during 'cool-down' due to air entering the cooling system, usually through a split hose end, rad cap gasket deformity, loose clamps, or any condition that would allow air to enter the closed system.
Pressurizing the system may help locate a leak (pump attached to the radiator neck). Use of a coolant dye may help: http://www.ehow.com/list_6152570_coo...ion-tools.html
If a rad cap is needed, you will find that most caps are made by
STANT, and packaged for sale under many brands, including ACDelco. New caps are made for both 'open' and 'closed' systems.
To Low Coolant Light??
