Are these basically the same?
Old Jun 27, 2014 | 07:42 AM
black_89_vette's Avatar
black_89_vette
Default Are these basically the same?
Is the Vette Brakes and Products camber relocation bracket the same as the Doug Rippie camber brackets?
http://www.vbandp.com/index.php?page...emart&Itemid=1
http://dougrippie.com/products/drm-camber-rod-bracket/
Old Jun 27, 2014 | 07:38 PM
BOOT77's Avatar
BOOT77
I asked VBP if they were the DRM brackets this last winter, "We are not familiar with the DRM bracket;
it may be similar or same as the ones we make.".
Old Jun 27, 2014 | 10:28 PM
Rob31's Avatar
Rob31
mp .
Old Jun 28, 2014 | 03:54 AM
gerardvg's Avatar
gerardvg
Hi
I have gone to Banski rear camber setup with precise camber settings, i have checked the camber rods and is very central to the suspension movement. May go with offset mounting points in future depending on the ride height.
Am now waiting for my trailing arms.
http://www.ebay.com/itm/C4-Corvette-Rear-Suspension-Rod-End-Camber-Rods-/160985547857?pt=Motors_Car_Truck_Parts_Accessories&hash=item257b7c8451
http://www.ebay.com/itm/C4-Corvette-Rear-Suspension-Rod-End-Trailing-Arms-/160985547830?pt=Motors_Car_Truck_Parts_Accessories&hash=item257b7c8436
Old Jun 28, 2014 | 09:24 AM
aboatguy's Avatar
aboatguy
Originally Posted by gerardvg
Hi
C4 Corvette Rear Suspension Rod End Camber Rods | eBay
C4 Corvette Rear Suspension Rod End Trailing Arms | eBay
Banski's suspension parts go well with the DRM brackets...
Old Jun 28, 2014 | 10:32 AM
black_89_vette
My plan is to go with the full Banski kit as well. I just purchased the camber rods and they are now installed.
I wanted to go with the DRM camber brackets, but they are out of stock and I can't find any on the internet. Also, they didn't answer my email about them, so I chose to go with the VB and P ones.
Old Jun 28, 2014 | 02:15 PM
BOOT77's Avatar
BOOT77
They been out of stock since early winter I think. Also didn't return my email either and I haven't needed them yet so I haven't called. I'll prob end up calling this winter as it looks like it'll be a next year project.
Old Jun 28, 2014 | 05:59 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by Rob31
I have used the VBP . And the holes are over 1/10 larger than the stock holes . Im referring to the bolts that mount it to the rear end . In other words the brakets can move around . I don't know why VBP would make the holes larger than they have to be . Apparently they don't know either .I have pics ,have to load them up .
I'd think they only do the brackets for M12 hardware that was used on the later C4's. If your car is an earlier C4 then your solution would have or should have been to bore the differential housing and the cover to accept the M12 hardware that was/is required on the later C4's.
What year is your car? Is the rear from maybe an earlier C4 and changed for the axle ratio. VBP I would have thought could have easily explained the difference. VBP mentions applications '90+ but the M12 hardware was used earlier than that.
Old Jun 28, 2014 | 06:23 PM
Rob31's Avatar
Rob31
That makes sense . I have an 86 with a dana44 out of a 85 .
Old Jun 28, 2014 | 11:11 PM
BOOT77's Avatar
BOOT77
Good to know the hardware changed, I'll have to keep an eye out for suspension parts fitment with my 86.
To Are these basically the same?
