another insturment panel question
Old Jun 29, 2014 | 08:34 PM
ghoastrider1's Avatar
ghoastrider1
Default another insturment panel question
1986L.
may have happened after install of new battery..took about 8 tries with quick on off with bolt and cable.
OK, lights are no longer bright. seems the flasher light(s) stay on but not flashing unless I want them to by engaging the system.Seems the RPM and SPeed light s are the most affected but perhaps that's just cause their more noticeable. thanks.
Old Jun 30, 2014 | 02:43 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
...took about 8 tries with quick on off with bolt and cable.
Does that mean it took 8 tries to get the cable properly bolted to the batt terminal??
Old Jun 30, 2014 | 07:29 AM
ghoastrider1
yes, but that's a loose number. other things were going on when I was doing that(not corvette related).only reason I added that was it may be needed to know.
Old Jun 30, 2014 | 08:15 AM
65Z01's Avatar
65Z01
In that case I'd double check the cable contact with posts.
Old Jun 30, 2014 | 05:40 PM
ghoastrider1
its not the battery nor the connection. just replaced the trans..thats why it was unhooked for some time.
To another insturment panel question
