Car got rained on....alarm goes off.
Old 07-29-2014, 01:33 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Default Car got rained on....alarm goes off.
Car almost always gets parked in the garage. I got parked outside yesterday as I'm doing a rear main seal job and wanted the extra space in the garage.
Anyway, POURED rain yesterday, last night...this morning, alarm (horn) starts going off. I went down, unlocked it, locked it, walked away. 1/2 hour later, alarm goes off again. Now it's just unlocked.
'92 BASE (not PKE)
I bet it will dry out and be fine.
Old 07-29-2014, 02:07 PM
DanielRicany
DanielRicany's Avatar
I wish I could say that about some of the problems on my car!
Old 07-29-2014, 04:23 PM
tbirdsps
tbirdsps's Avatar
It's trying to tell you something.
Old 07-29-2014, 07:40 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
You can be having a problem in the door jamb switches...which can go bad.
I have also run into the black plastic push in plug that goes in the lock pillar area where the switch actually contacts....may need to either be replaced or removed and a thin washer placed behind it and pushed back in. This will space it out slightly and allow the door switch to not be as sensitive.....BECAUSE I have experienced this before. And sometimes the battery goes dead due to the interior lights are on ....due to the switch.
DUB
Old 07-29-2014, 11:33 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
I will lock it tomorrow morning. If the alarm goes off again, I'll look to see if the interior lights are on. I agree that a door switch is a possibility.
Old 07-30-2014, 02:19 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
I thought Vettes melt in the rain
Old 07-30-2014, 02:40 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Door switch or the key/arm switch.
Old 07-30-2014, 06:59 AM
cudamax
cudamax's Avatar
The problem is you left it outside in the Rain and it's telling you to put it back in the Garage and only take her back out on Sunny Days and I'd say also spray those darn door jam Switches
Old 07-30-2014, 07:06 AM
cudamax
cudamax's Avatar
And this is another reason why its always better not to get-em wet
Old 07-30-2014, 08:25 AM
T. Wayne Nelson
T. Wayne Nelson's Avatar
Tom, if the horn goes off in the rain while driving, that could cause several problems. One, your wife thinks you honking at the ladies, and, or, other drivers think you are rude....
Old 07-30-2014, 07:43 PM
DUB
DUB's Avatar
The door switch mounted on your door is what triggers the alarm and IS THE PROBLEM. It is grounding and setting off the alarm. This is from experience and knowing the system. The switch that is on the backside of the door lock cylinder is what dis-arms the system...and it is not the problem.
I seriously doubt it had anything to do with the rain. Just dumb luck and timing....and I can not buy into that one. UNLESS...some BOZO has gotten into your doors and messed around with the wiring. But a factory set-up that has not been modified or damaged..I seriously doubt it.
DUB
To Car got rained on....alarm goes off.
Quick Reply: Car got rained on....alarm goes off.
