Bad engine vibration
Old Aug 5, 2014 | 11:11 PM
octaneforce's Avatar
octaneforce
Default Bad engine vibration
All of the sudden my 89 is vibrating like crazy. When the air is on its almost unbearable. It does it in any gear (including neutral. Zf6) from about 2400-3000 rpm and then tapers off. With the air off its much more faint but i can still feel it. Ive never done plugs, wires, cap, rotor, any of that tune up stuff since ive had it. Im hoping its just a misleading misfire. Pulleys seem okay. Belt and tensioner are fairly new. So is the smog pump delete pulley. Looking for insight since i really dont know where to turn.
Old Aug 6, 2014 | 02:54 PM
hooked073's Avatar
hooked073
If you can feel vibrations I would check the motor mounts
Old Aug 6, 2014 | 04:47 PM
Race Prepared's Avatar
Race Prepared
Consider, you may have thrown a weight off the drive shaft or have a bad u-joint.
Old Aug 6, 2014 | 08:03 PM
octaneforce
I can feel the vibration sitting still when i rev the motor. Which is steering me away from driveline possibilities
Old Aug 6, 2014 | 08:04 PM
octaneforce
I dont feel the engine knocking around between shifts. The car is tight. But i mean, poly mounts couldnt hurt right?
Old Aug 6, 2014 | 08:53 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Pull the serpentine belt and run the engine.
Take it for a drive. Not far, just enough to trouble shoot the vibe.
Remember the water pump is shaft driven by the opti not the belt.
Old Aug 6, 2014 | 09:14 PM
ex-x-fire's Avatar
ex-x-fire
Could it be a misfire? Mist the ign. wires with water when its dark out & look for arcing.
Old Aug 6, 2014 | 09:18 PM
octaneforce
Is this true for the l98?
octaneforce
Im hoping its that simple. I mean its due for a tune up but I'll pull the belt and see what happens
Old Aug 6, 2014 | 09:53 PM
cohocarl's Avatar
cohocarl
No, an 89 L98 would need the belt on to run the water pump. If I ran it w/o a belt, it would be startup from cold, then not run it more than 30 seconds or so....
Do you hear any knocking like maybe a dual mass flywheel problem?
Old Aug 6, 2014 | 09:55 PM
TA's Avatar
TA
Not on an L98
Old Aug 6, 2014 | 11:12 PM
octaneforce
Hmm i dont think so. Defintely more of a vibration not a knock. Its so consistent. I may do a tune up regardless and see what happens.
Old Aug 6, 2014 | 11:18 PM
cudamax's Avatar
cudamax
If its felt in park while reving I'd say wires and its a Engine miss
Old Aug 6, 2014 | 11:19 PM
jake corvette's Avatar
jake corvette
One thing to check - make sure the front pulley - harmonic balancer - is not loaded with mud or other dirt on the inside.
Jake -
Old Aug 6, 2014 | 11:39 PM
octaneforce
Jake -
Will do
Old Aug 7, 2014 | 09:06 AM
davewhtt's Avatar
davewhtt
Thats the FIRST thing i would do!
Old Aug 7, 2014 | 10:39 AM
383vett's Avatar
383vett
Ive never done plugs, wires, cap, rotor, any of that tune up stuff since ive had it. .
Change plugs, wires, cap, rotor, etc.
To Bad engine vibration
Old Aug 28, 2014 | 06:27 PM
octaneforce
Changed plugs, cap, coil, rotor, wires, pcv valve. I think its actually running worse. And my vibration hasnt changed at all. Pretty dissappointing especially considering the horrible coniditon of the old parts. The wires were practically crumbling in my hands.
Old Aug 28, 2014 | 06:57 PM
s carter's Avatar
s carter
you know folks I think we are missing a key fraise here he claims the vibration is with A/C on I agree with a few posts back release the drive belt to rule out things. but truly I think the A/C compressor has seen its last hot day, or some kind of over pressure.
Old Aug 28, 2014 | 07:58 PM
cudamax's Avatar
cudamax
Post a video with a clear glass of water half full on the dash and tell me have you pulled the belts and run it that way to see if it goes away or stays the same? That would help get to it
