Something else needs attention. Stock LT4 peaked at 5800. How did adding a HOT cam drop peak power 300 RPM?
Its got valve control problems.
You can see it plain as day on the dyno graph starting at 5200 rpm.
I would first suspect old valve springs or inproper spring set up... but something as simple as the rocker/valve train geometry not being correct would also cause it.
Will
Will
We used the new springs with the Hot Cam Kit. Plus I think if it were were valve train geometry or problem with the springs, the lower rpms would show signs as well.
We think it is fuel related.
I don't agree. Fuel delivery problems will show up as lean, and increasing the injector dwell time won't fix it.... power output just flatlines nice and smooth like.
On the other hand valve control issues show precisely what you have. Good power to a certain RPM then a choppy curve with power dropping dramatically as the springs cannot recover control of the valves closing event.
Will
Will
Thanks for the input. Maybe I will change to better springs over the winter and see. Of course I will probably try the fuel pump first and see if that makes a difference. I would have thought that the springs with the LT4 hot cam kit would have been sufficient enough, but maybe not.
FWIW when I had a stock bottom end, hotcam, reworked LT1 heads, headers, and factory exhaust, I made 362hp through a 3000 stall converter. It made power past 6000 rpm actually was still making power at 6,200 rpm when we shut it down. Also, this was all done with stock injectors and stock pump.
Looking at your dyno sheet it is really hard to see, but it appears you still have plenty of fuel, you are not going lean.
As Will said, I would check your valve train geomentry first.
Yes it is starting to go lean just after 5500rpm. We were trying to maintain 12.5 f/a mix but we couldn't maintain it after 5500.
Originally Posted by Drew95
What's good about these numbers? They're under LT4 expectations, and he got a tune?
Do you have a good example of the expectation of a similar set up LT4?
I'm going to go on the assumption that this is a true LT4 as opposed to LT1 w/ hotcam kit.
If so the springs in the kit are the same as the stock springs. Now, if you used the rockers, which I believe are also in the hotcam kit, they are going to be different than the stock rockers, I'm sure you know that.
Another thing to look at would be the lifters and pushrods. Although they would be pretty much the same, if the lifters are older, perhaps they're not keeping up at the top end?
But numbers wise, it seems like it's about where it should be. The Hotcam is a pretty mild cam. I would think that a 40 or so gain at the crank from the cam and the headers should be about right.
did you go with 1-6 ratio rocker arms? Thats what the hot cam is designed to be used with
I used the stock 1.6 rockers that are stock with an LT4.
Yes this is a true LT4. Rebuilt due to spun bearings. Stock LT4 Heads. We used the new springs from the Hot Cam Kit and re-used the stock rockers. I sold the new Rockers in the kit to another fellow.
I am content with the gain. What surprised me actually was the torque out put. It was higher than what I thought it would be.
As long as you are happy with the gains then that is what matters! We can all speculate why it may not be putting down more hp but ultimately you are the driver. Good luck and have fun.
I also agree that it looks like valve float to me. The fuel pump may be fine, you need to monitor fuel pressure and if it is not dropping the pump is fine. A car will read lean when it starts to have valve float because the O2 sensor looks for oxygen in the exhaust and when the valves start to float there will be more oxygen in the exhaust. This happens combustion process is not complete and some of the fuel/air charge is ending up in the exhaust causing the sensor to read lean when it may not be lean. This is the same thing that happens when you foul a plug, the O2 reads lean but the car is not lean.
l98tpi, I've done some tuning & I agree with the valve control opinions. Something small like pushrod length can change the effective ratio. So it's not necessarily the springs alone.
btw, is the fuel filter new? If its old I'd change it before swapping the pump.
