need help bad
Old Aug 9, 2014 | 09:49 PM
crossno's Avatar
crossno
2nd Gear
Default need help bad
Me and my vette are same age june of 87 I'm wanting to put a hidden start up on it one switch to start the car one to enable and disable fuel pump but I need wiring diagram to do so
Old Aug 10, 2014 | 03:28 AM
Cliff Harris's Avatar
Cliff Harris
It would probably be easier to disable the voltage to the distributor. It's a pink wire that connects between the ignition switch and the distributor cap.
Old Aug 10, 2014 | 09:25 AM
cadmaniac's Avatar
cadmaniac
Distributor cut off is a good Idea.
Better make that a 30 amp switch.
That's a good size wire, like 10 gauge.
Old Aug 10, 2014 | 12:02 PM
crossno's Avatar
crossno
2nd Gear
Makes since take away fire and ou remove the ability to start
Old Aug 13, 2014 | 10:12 AM
LannyL81's Avatar
LannyL81
Need to get the service manual for your year Corvette for the details, but a switch in the fuel pump relay circuit will not require a large wire or switch contacts due to high current.
Old Aug 13, 2014 | 10:22 AM
93 ragtop's Avatar
93 ragtop
Just break the signal wire to the fuel pump relay.
Old Aug 13, 2014 | 12:55 PM
cudamax's Avatar
cudamax
Yours should be close to this on and just take ur pick on where to add a kill switch and you wont have to run anything from the engine bay. Theirs enough right there.
To need help bad
