High idle
Old Aug 17, 2014 | 10:04 PM
firsttimechevy's Avatar
firsttimechevy
Default High idle
Can an ECM make a car idle high on its own I have a 91 vette l98 has new fuel pump throttle body tps iac and still misfires and idles high
Old Aug 18, 2014 | 01:20 AM
Cliff Harris's Avatar
Cliff Harris
A high idle is almost always a vacuum leak.
I suggest a minimum idle adjustment:
http://forums.corvetteforum.com/1570563689-post1.html
Old Aug 18, 2014 | 11:57 AM
firsttimechevy
Default High idle
I checked for vacuume leaks and found none can the idle be adjusted on a 91
Old Aug 18, 2014 | 12:05 PM
79C3tnd's Avatar
79C3tnd
Not to sound like a know-it-all, but what method did you choose to check for leaks?
Old Aug 18, 2014 | 12:27 PM
firsttimechevy
Default High idle
Listen look and spray water and soap
Old Aug 18, 2014 | 08:24 PM
firsttimechevy
Default High idle
I noticed that the little port on my throttle body is sucking a lot of air without ac on its idles on near 1000 with ac on its 750 I pluged that port and idle is 500 and 450 with ac on any suggestions
Old Aug 19, 2014 | 12:24 AM
firsttimechevy
Does the iac run off a relay or fuse I took it off and idle stayed high then plugged it back in and no change and this is a new iac from summit
Old Aug 19, 2014 | 01:26 AM
Cliff Harris
Which "little port" is that? Do you have a picture?
Early throttle bodies have two ports, later ones have three. The one on the bottom goes to the EGR solenoid. The later ones with the vacuum port on the passenger side go to the charcoal canister (earlier cars got the vacuum from the intake manifold at the same place as the PCV valve). There is also a filtered air supply that goes to the passenger side valve cover, which is part of the PCV system (it's called CCV for CrankCase Ventilation in the shop manuals).
Old Aug 19, 2014 | 01:29 AM
Cliff Harris
The IAC is controlled by the ECM. It is actually a stepper motor and there is a stepper motor integrated circuit in the ECM that operates it. It only moves if the ECM tells it to move.
Old Aug 19, 2014 | 08:14 AM
firsttimechevy
Default High idle
The little port is the one in the throttle body it goes to the iac port it is in between the two butterflies on bottom
To High idle
