LT1 Timing set
Old Aug 18, 2014 | 04:35 PM
dchildress's Avatar
dchildress
Default LT1 Timing set
Pulled motor to install cam, lifters, rocker arms, clutch, oil pump & pan, and some long tubes along with some maintenence items. Keeping stock bottom end. Purchased a Melling stock replacement timing set but worried now about it coming apart. Cam is going to take me into the 6200 to 6500 range. Will a stock unit handle that? How do I go to an LT4 set without changing my MSD Optispark, cam, and water pump?
Old Aug 18, 2014 | 05:26 PM
blue94's Avatar
blue94
if it is a 94 or earlier you may have an issue you might want to call Coyles, when I did my 94 I had to change over to a gen-2 cover and opti.
Hopefully others will chime in.
Old Aug 18, 2014 | 07:53 PM
dchildress's Avatar
dchildress
It is a 94
Old Sep 18, 2014 | 04:54 PM
dchildress's Avatar
dchildress
Bumping...
Trying to figure out what it takes to get a roller LT4 style chain into my LT1, or figure out of a new stock LT1 chain can handle 6500RPM
Old Sep 18, 2014 | 07:37 PM
blue94's Avatar
blue94
you need a 95/96 lt1 timing cover a gen2 opti and a lt1 roller set. if you change to an Electric Water Pump you can use just about any SBC dual roller setup.
Old Sep 18, 2014 | 07:52 PM
rklessdriver's Avatar
rklessdriver
To upgrade the timing set on a 92-94 Corvette you have to change over to the 95-96 cover & pin drive opti. Then you can use the single roller LT4 extreme duty which is still not that great or the best option is a 87-91 SBC double roller (requires elect water pump).
Otherwise the Melling replacement timing set you have is the best thing going... which isn't saying much for a 6000rpm engine with a big cam and heavier valve springs.
Will
To LT1 Timing set
