93 rough idle
Is there a computer relearn procedure for this model?
Sounds like you have a problem with the system.
You say you can "feel" all injectors pulsing but have you put an injector tester on each injector. They are very inexpensive and you can test each injector separately.
How about the old drop of water on each exhaust manifold to see if they are hot (firing) or even neater an infrared thermometer to make certain which cylinders have combustion and which don't.
Do you have a spare or can you borrow a spare 93 CPU? It only takes a 10 mm socket and 2 minutes to pull out and change out. You would need to pull your chip and put it in the new and that would tell you if it is a problem in the CPU wiring with one exception, and that is if the short/bad connection is in the pin in portion going to the mass of wires that are collected in the wire bundles that slide onto the ECU.
I do not have my helms here as my 93 is at a remote garage, but you should find the pin in that controls each bank of injectors and make sure that connection is inserted correctly.
As Harris says, it also seems like the time to carefully follow the wiring diagram and find out if you have a short.
BTW, the 93 ECU is the same part in the Y Body as in the F Body. The chip is different but the ECU itself is identical. So if you can find an ECU for a Camaro/Firebird from 93 you are good to go. Just change the physical CalPack Chip and put the ECU into your car and see what happens.
Where are you located?
92-93 Corvette, 93 Camaro/Firebird ECU
