ford performance or Accel injectors?
Old Jul 28, 2002 | 12:54 AM
corvette4life's Avatar
corvette4life
Default ford performance or Accel injectors?
I need to get a new set of injectors for my 383 I'm building. Should I buy Accel or Ford motorsport injectors?
Thanks,
Kerry
Old Jul 28, 2002 | 01:01 AM
gtsyellow's Avatar
gtsyellow
Default Re: ford performance or Accel injectors? (corvette4life)
this is a no brainer..ford..there have been more reports of problems with accel injectors than any other brand i've read about. i've tried the accel injectors and they won't even hold psi for more than 20 seconds when you shut them off. the ford injectors are similar quality to bosch/gm and MUCH better than the accel's. i'm sure you'll find someone who has accels and swears by them if you look hard enough however. it's kind of like tire posts, someone replaces there 5yr old tires with brand X & swears they are the greatest thing since sliced bread.
Old Jul 28, 2002 | 01:57 AM
vader86's Avatar
vader86
Ford SVO's, #30's are what 383's usually call for
Accel has had tons of problems.
Old Jul 28, 2002 | 02:11 AM
Corvette0096's Avatar
Corvette0096
Svo :yesnod:
Old Jul 28, 2002 | 03:56 AM
pablocruise's Avatar
pablocruise
running Accels here. They're running, but I am not impressed with them.
Old Jul 28, 2002 | 01:26 PM
SpedRacr93's Avatar
SpedRacr93
I have both in 2 different cars. Both work fine, never had a problem with either.
Buy the fords, they're cheaper.
Old Jul 29, 2002 | 12:14 AM
The Green Rocket's Avatar
The Green Rocket
I run the Ford SVO 30# injectors in mine - just beware that the Ford/SVO injectors reach their rated fuel delivery at 39 psi. If you run more/less fuel pressure you will have to calculate actual fuel delivery: divide actual psi by 39, then multiply by SVO # rating. E.G., 35 psi/39 psi all times 30# = 27# or another example: 43 psi/39 psi all times 30# = 33#
I run mine at 39 psi and adjusted the fuel trim in the computer.
Thomas
Old Jul 29, 2002 | 05:24 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Injector flow varies by the square root of the pressure change. So 30# injectors rated at 39 pis and are operated at 43 psi will flow sqrt(43/39) * 30 = 31.5 #.
Old Jul 29, 2002 | 06:02 AM
5abivt's Avatar
5abivt
Default Re: ford performance or Accel injectors? (AquaMetallic94LT1)
what about 24# svos in a stock lt1. is it good to turn the pressure down to 39 psi?? i figure the shoppe had it too high at 46 or 47
Old Jul 29, 2002 | 07:59 AM
gtsyellow's Avatar
gtsyellow
Default Re: ford performance or Accel injectors? (5abivt)
i agree that is too high for a stock lt1 with disc injectors, car should be better about 39psi, the fords flow more at lower psi than the bosch gm design. i think the fords are rated at 38-39 psi where as the bosch are at 44psi-ish.
Old Jul 29, 2002 | 12:11 PM
Guest
Guest
Posts: n/a
Another vote for SVO here....I'm running 24# on a 383 and have plenty of fuel delivery. :yesnod:
Old Jul 29, 2002 | 12:18 PM
vettmech's Avatar
vettmech
Default Re: ford performance or Accel injectors? (Mark84_L383)
I use 24# Ford ones because when mine went bad they were cheaper..... very happy with them ....... lots of miles on them and all kinds of digfferent gas has been through them
To ford performance or Accel injectors?
