84 performance chip
Old Aug 25, 2014 | 08:56 PM
84vete's Avatar
84vete
Default 84 performance chip
Was thinking about putting the thermo master chip stage 2 from corvette central so i can run my engine cooler any suggestions? I already done the cold air mod to it and hi flow air filter, also already have magnaflow cat back exhaust and mild shift kit in transmission due to prior owner
Old Aug 25, 2014 | 09:21 PM
playsdixie's Avatar
playsdixie
pretty much think it's a unversal opinion on this forum. that there's no value in them...I had a hypercrap chip..(still have it if you want it} but noticed no differeence in power....it's much easier to install manual switches for your fan or fans....a couple of bucks at best....I did have mine come on early when I had my chip re tuned, but I still have and use the manual switches. with a lower t stat....you"ll have no problem....
Old Aug 25, 2014 | 09:51 PM
84vete's Avatar
84vete
It said something about improves throttle response and allows me to use 160° thermostat
Old Aug 25, 2014 | 10:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You don't need a chip, to "allow" you to run a 160 stat. You can go ahead and run what ever stat you want, w/the stock chip.
CFI-EFI and others have tried various aftermarket chips that went slower (documented) with them...went back to stock and sped back up. Optimize your own fuel pressure, base timing and you'll be way ahead of anything a chip could possibly do for you on an '84.
Old Aug 25, 2014 | 11:20 PM
84vete's Avatar
84vete
Sounds good wont get the chip but what about the "hi- performance" pulley set that corvette central offers its part number 304719
Old Aug 25, 2014 | 11:35 PM
psychodiagnostik's Avatar
psychodiagnostik
I tried that stuff 15 years ago in my '93 LT1 Z28, although it was a bit different from your L98m I didnt get anything out of them. Except a little less comfort from the heater on really cold mornings!
There are some good write-ups on this forum (I think maybe by vader86) that go thru where to get started on L98 performance.
One of my friends did that stuff with the underdrive pulley & even then there wasn't a real difference.
Old Aug 26, 2014 | 12:26 AM
qws's Avatar
qws
First, lets clarify. A 1984 is a L83 not L98
Second, Aftermarket chips are junk... I've already proven that once on a dyno.
Third- Save your money on the underdrive pulley set as well. Been there done that... and Not Impressed.
whats next?...lol
Old Aug 26, 2014 | 12:28 AM
ToniJ1960's Avatar
ToniJ1960
Pretty sure on the 84 fan isnt controlled by the ecm.
Old Aug 26, 2014 | 09:59 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
about the fan. Not ECM controlled in '84.
The problem w/underdrive pulleys isn't that they don't work....they do provide a slight increase in power and efficiency. The problem is the cost, for that power. For the money you can get a LOT more power elsewhere. Like exhaust, rockers, cam, ported intake.... for starters.
Old Aug 26, 2014 | 10:02 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by qws
whats next?...lol
MSD ignition stuff, 8.8mm wires, E3 plugs, K$N air filter, .030" over bore, and a can of elixir.
Old Aug 26, 2014 | 11:07 AM
tunedport85inject's Avatar
tunedport85inject
It's proven to be the best bang for the bucks in this engine 1.6 RR , headers,exhaust, and intake porting . More bucks... More options... HP =money 😄
Old Aug 26, 2014 | 11:31 AM
corvettenorway's Avatar
corvettenorway
Originally Posted by tunedport85inject
It's proven to be the best bang for the bucks in this engine 1.6 RR , headers,exhaust, and intake porting . More bucks... More options... HP =money ��
a max ported inntake ( or a renegard ) + more fuel + more timing + better air filter and a full tune http://forums.corvetteforum.com/g/album/1347303
Old Aug 26, 2014 | 02:56 PM
playsdixie's Avatar
playsdixie
I put new heads/1/6 roller rockers/ headers/ 52mm throttle body....tire smoker now....don't know why you need any more beef...unless you're worried about 1/4 times....
the kids with thier suped up nip cars with their gearing cant' touch me...
good enough for me....
Old Aug 26, 2014 | 05:11 PM
MrWillys's Avatar
MrWillys
To the best of my knowledge the 84 ecm has never been hacked for reprogramming and would require an adapter to convert to a newer ecm? Adapter would be the Racetronix RHCA-001.
To 84 performance chip
