Rear spring bushings
Old Aug 27, 2014 | 09:29 PM
v8vette84's Avatar
v8vette84
Default Rear spring bushings
I have a question. I am replacing the rear spring bolts and bushings and I am wondering why mine are different. Here is a picture I found of a regular C4 setup.....
Now, my spring bolts have the normal bushing shown i nthe photo above PLUS 2 extra bushings and a spacer that go from the bottom of the upper mount to the top of the spring.) Basically stopping the spring from being compressed past a certain point. Is this normal or an aftermarket piece? Just trying to put my diff back in and I want to make sure it's installed correctly.
Old Aug 27, 2014 | 09:33 PM
v8vette84's Avatar
v8vette84
Here is my basic setup. (made in paint not photoshop so don''t be too mean) haha
Old Aug 28, 2014 | 06:44 AM
WVZR-1's Avatar
WVZR-1
That spacer and the bushings would have only been found on '84 and '85 cars and "only" with FE7 HD suspension.
Old Aug 28, 2014 | 08:51 AM
rklessdriver's Avatar
rklessdriver
Yep.
v8vette84 - You can remove the inner bushings and inner spacers and use the later style set up with only the 2 outside busings.
I did so on my 84 Z51.
Will
Old Aug 28, 2014 | 10:53 PM
v8vette84's Avatar
v8vette84
Ok, cool thanks for the replies. Yes it's an 84' with Z51 and FE7 options. When I read about removing the leaf spring and it turning into a "U" I was a little worried about reinstalling it. But the spring really didn't bend much more than it already was... Maybe an inch or 2 down on the ends when unbolted. I was expecting a lot worse.
To Rear spring bushings
