Need advice on HEI replacement unit. ...LOOK inside...
Old Jul 28, 2002 | 05:52 PM
Hole-Shot's Avatar
Hole-Shot
Default Need advice on HEI replacement unit. ...LOOK inside...
While replacing my distributor cap yesterday, I noticed that my HEI wires are brittle and falling apart. Does anyone have a recommendation for a good aftermarket HEI unit (complete w/ wires)?
I would prefer a high performance unit to work in conjunction with the Hypertech high voltage cap that I just installed. This is for my 87 w/383. Thanks!!:cheers:
Old Jul 28, 2002 | 06:22 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Need advice on HEI replacement unit. ...LOOK inside... (Hole-Shot)
Looks like those are wires on the dist, not the external harness.
In that case you might get a good used one from Contemporary Corvette (link on my site).
Old Jul 28, 2002 | 11:06 PM
Hole-Shot's Avatar
Hole-Shot
Default Re: Need advice on HEI replacement unit. ...LOOK inside... (65Z01)
Quote {Looks like those are wires on the dist, not the external harness}.
If this is the case, will I have to put in a new distributor or can the wires be replaced separate from the rest of the unit?
Old Jul 28, 2002 | 11:12 PM
1MoorTym's Avatar
1MoorTym
The dealer carries that for less than $20 I believe (can't remember exact price from when I bought mine).
No need to remove the distributor.
[Modified by 1MoorTym, 9:14 PM 7/28/2002]
Old Jul 29, 2002 | 05:18 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Need advice on HEI replacement unit. ...LOOK inside... (1MoorTym)
That sounds about right. I think I have a spare (new OEM) one of those in my parts box (different part for my 90 from your 87 though I think). Check with your GM parts source for this one.
[Modified by Red 90 L98 Coupe, 7:19 PM 7/29/2002]
Old Jul 29, 2002 | 08:45 AM
Bluevette85's Avatar
Bluevette85
Any auto store should have it. They call it an ignition suppressor/capacitor and cost <$10. The wires and plug are part of it. You may want to replace the other set of wires that go from the ignition module to the computer. GM #1986260.
Old Jul 29, 2002 | 12:02 PM
Hole-Shot's Avatar
Hole-Shot
Default Re: Need advice on HEI replacement unit. ...LOOK inside... (Bluevette85)
Thanks for the info, I appreciate it!! :cheers:
To Need advice on HEI replacement unit. ...LOOK inside...
