Wet Opti
Old Sep 8, 2014 | 08:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by woodyupstate
The opti isn't too big of a deal at this point since this all started with a blown radiator hose and the hoses are all off and the coolant is drained. All that's left is to remove the water pump.
Water pump, harmonic damper, and then the opti. You're right; that is pretty easy. Maybe an hour?
Old Sep 9, 2014 | 06:59 PM
woodyupstate's Avatar
woodyupstate
Cleaned & dried the opti harness. No result. Removed water pump and unbolted harmonic damper but cannot get it off the shaft. Soaked it good in PB Blaster to no avail.
So, next question. . . How to get the pulley off? Bearing puller?
Old Sep 9, 2014 | 07:45 PM
woodyupstate
Ok. I found the thread on HB removal. 2x4 and a BFH.
Old Sep 9, 2014 | 10:43 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yep. Thump it, turn it thump it...it will come of quick.
Old Sep 15, 2014 | 06:45 PM
woodyupstate
Successfully removed the harmonic balancer pulley this afternoon. New opti arrives Wednesday.
Old Sep 15, 2014 | 11:14 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Test the old one in the mean time?
Old Sep 15, 2014 | 11:25 PM
Pete919's Avatar
Pete919
What opti did you end up getting? Just curious, I think I'll be replacing mine soon.
Old Sep 16, 2014 | 12:03 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
NAPA. At the time I was living in Telluride, Colorado....AKA, The middle of no F'ing where.
I had a trip coming and mail order wasn't going to do it. Only distributor I could find on the "western slope" as it's called, was a NAPA in Grand Junction. Grabbed it, installed it, drove to 'Vegas the next morning. Whew!
I was worried; have I gotten the "right" one? All the posts you see on here; MSD rules/sucks. Petris rules/sucks. AC Delco, rules/sucks, and on, and on. Mines gone 2-1/2 years now, and about 20k miles, hasn't missed a beat on the street or track, so I think I did O.K.
EDIT. Whoops...didn't look and thought you were the OP, asking me. Sorry.
Old Sep 16, 2014 | 01:43 PM
woodyupstate
I ordered the ProComp from SacCityCorvette for $160, or so. They were all backordered, but they had an AIP and said it was equivalent. I said, "okay." They were very good to deal with. Calls and e-mails were prompt and courteous.
Purchased a fuel pressure tester today to test the opti as was suggested.
Old Sep 16, 2014 | 02:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Now that you've got the opti out, you can simply test it like I did in the video that I posted. If spinning it w/it hooked up provokes fuel pump, AIR pump, etc, then that is pretty strong evidence that it's working. If nothing, then it's dead.
Old Sep 16, 2014 | 04:24 PM
woodyupstate
Removed opti and tested as suggested with harness wire attached, fuel pressure tester attached, coil wire off and near ground, manually spun opti with ignition on.
Fuel pressure stayed at 42 psi, AIR pump did not run, no spark from coil wire.
It appears my opti is dead.
New opti arrives tomorrow. Reassembly the day after.
Here's hoping for a great September drive on Saturday.
Old Sep 16, 2014 | 04:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sounds pretty conclusive! Fingers crossed for you for Saturday!
Old Sep 16, 2014 | 05:31 PM
  #33
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You can pull the cap on the opti and clean it out
my cap was all eroded when I looked
at least you'd have a spare
Old Sep 16, 2014 | 07:27 PM
  #34
woodyupstate
I plan to give the old cap a good going-over. The bearings seemed quiet and smooth when I spun it. It may very well be worth saving as a spare.
Old Sep 16, 2014 | 11:06 PM
  #35
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If the opti isn't triggering any activity in the ECM, no amount of cap cleaning is going to help it.
Old Sep 17, 2014 | 07:53 AM
  #36
woodyupstate
So, in may anxiousness about removing a stubborn HB, I didn't note it's position when I removed it. Ugh. Is this going to be a problem reinstalling? Does the arrow on the pulley align with TDC?
Old Sep 17, 2014 | 09:05 AM
  #37
BrianCunningham
No, but if you clean the optics, it could start working again.
To Wet Opti
Old Sep 17, 2014 | 09:06 AM
  #38
BrianCunningham
Did you remove the mount as well as the balancer?
It's two pieces.
Old Sep 17, 2014 | 09:10 AM
  #39
woodyupstate
No. I only removed the pulley. The 3-spoke bracket is still on the crank.
Old Sep 17, 2014 | 09:51 AM
  #40
BrianCunningham
You're in luck then
There should be a mark on both
http://www.superchevy.com/how-to/16758/
