Need rear gear
What kinda rear gear will I need and where can I buy it from? Will a 1999 tahoe 3.42 rear gear fit the dana 44?
There are some Jeep rears that will fit but if you don't know what you're doing you're best not to try.
If you want used there should be likely a few available as a WTB here on the forum.
An install depends upon ones talent, if you need to pay then discuss it at length with the shop/individual that you expect to do it. You'll need an install package of 6 bearings, 3 seals, the shims and hardware generally done in one package. It can be done with less hardware but there's no good reason to half a$$ it.
Availability/vendors up to you - everybody has them. Good luck!
Thanks a ton for the help bud!
Obviously, the most "fun" thing is gears. If you want to do a HSR, you are going to need ECM tuning. You also need to cut a hole in your hood to let the HSR fit.
I really think some gears would wake the car up over the 3.07's.
Gears allow the car to accelerate faster, an engine makes power as rpm climbs at 1000 rpm a 400 hp engine makes say 100 hp 2500 250 hp and so on till max hp at or near max rpm 3.08 gears you are out past 60ft before you hit max rpm which =max power w/4.88's you've already hit max rpm and are in second gear,so for that first 60 even though the guy in the next lane had same power as you his power was available sooner, and he's ahead of you. In case w/c5 vettes equipt w/3.42 vs 4.10 w stock motors they are very close (et & mph) as fuel and timing curves were optimized for the 3.42 gear equipt cars from the factory.Thats why a tune is import when mods are done; as tune to the 4.10 car takes advantage of the quicker accelerating engine by adjusting fuel delivery and spark curves and as mods are done (heads cam) remember to make more power more air /fuel must get in and out of engine cam opens sooner closes later to take a bigger gulp of air/fuel mixture end result more power on top but start to lose on bottom end (as valve is opening sooner in the cycle and closing later and there is a loss of cylinder pressure) [squeeze]so a loss of low RPM POWER. This is where gears come into their own as they allow the engine to get up to where it makes power.
Gears like every other mod are just a part of the whole package very few things by itself will be a "MAGIC BULLET" So to answer gears help a stock equipted car marginally but modded are necessary. If gears are the plan and car is to stay totally stock a tune would be advised and if any mods are planned it is probably one of the better mods you could initially do.
This is a great website, pan down, select your car, tire height, redline, etc and see where you stand at redline with various gears.
http://xse.com/leres/ss/calculator.html
I'm back to 2:58 now. Bought both pumpkins off Ebay
I thought that rear-gears were an item that wont need tuning?
Only time I went to the track and trapped a 9.6 @ 77..... with a 2.6 60ft... on my OEM 27 year old tires :shame:
It is similar to a regular D44 (same size ring gear) but the D44HD uses a 29 spline pinion like the Dana 60/70 and larger ID pinion bearings. The carrier bearings are actually smaller ID than the regular D44's.
The gear set is used in some Jeep WK Grand Cherokees, Wrangle Rubicons and Dodge Vipers. but the housings are different between all of them. Some of the ring gears have a different bolt size... 2nd GEN Vipers and most Jeeps use a 7/16" bolt while some early Jeep Rubicons, 1st GEN Vipers and the C4 Corvette use a 3/8" bolt...
Most aftermarket gear sets are drilled for both sizes but OEM SPICER gear sets are one or the other.
Factory ratios for the C4 Corvette D44HD were 3.07 (common), 3.33 (very rare), 3.45 (common) and 3.54 (rare).
Aftermarker gear sets are availiable in 3.73, 3.90, 4.11 and 4.30 from Yukon Gear. I have used a number of thses gears and like them... they set up easy and it's easy to find what you need on their main sellers web site (Randy's Ring and Pinion)....
Also be aware there is a Ford front end in 4WD trucks that is often refered to as a "D44HD"... this front end does not share any compatible parts with the Corvette/Viper D44HD.... This is a very obscure front diff.... not common at all..... It was a reverse rotation D44 front end with 8 lug 3/4 ton outer hubs. This diff makes things even more confusing for those that don't understand differentials.....
As for tuning... depends on the year of the car. OBD2 cars can have the speedo changed via the PCM to read correctly.... earlier cars have to have the gear changed on the speed cable that goes in the tranny tail shaft.. sometimes both gears (speedo cable gear and the tranny output shaft gear).
Will
Also,
I'm not calling anybody a liar.. but I've NEVER heard of needing to retune a car when installing different gears other than to set the speedometer. What kind of engine parameters need to be changed for a lower gear???
Although, these changes are relatively minor, they do affect TCC and/or 4+3 overdrive control and overall drive-ability.
In general, it makes sense for the tune to fit the car's configuration and driver's preferences. Since tuning is so easily accomplished on these cars, and can be done for very low cost, why compromise?
