Testing for leaking injectors
Old Nov 10, 2014 | 07:35 AM
aklim's Avatar
aklim
Originally Posted by Cliff Harris
When you do an injector leak down test you don't need to connect the injectors. You're doing a mechanical test to see if the pintle in the injector is sealing, not an electric test.
True but just because it holds pressure doesn't mean the spray pattern or volume is correct, does it?
Old Nov 10, 2014 | 08:12 AM
1993C4LT1's Avatar
1993C4LT1
Thanks. Figured I didn't have to, just wanted to be sure. It leaked both ways.
Old Nov 10, 2014 | 09:15 AM
aklim's Avatar
aklim
But lets say it does or doesn't, why do you want to keep the junk? Why waste time diagnosing bad junk? If I am worried about a leak and I have fresh injectors, I know it probably isn't them and can go on.
Old Nov 10, 2014 | 09:56 AM
1993C4LT1's Avatar
1993C4LT1
Very true
