Dyno tomorrow, make a guess.
Old Aug 2, 2002 | 07:42 PM
scorp508's Avatar
scorp508
Default Dyno tomorrow, make a guess.
Ok guys tomorrow the car goes on the dyno for a baseline before it has been tuned.
So far the car has run a 12.89 @ 108.66 in very muggy 90 degree temps. Highest MPH so far has been 109.66. It picks up between 24-27 MPH in the last 1/8th mile depending on the day and how I'm shifting.
Guesses? Personally I'm thinking about 300-310 rwhp, and no clue on the torque.
Old Aug 2, 2002 | 07:49 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default Re: Dyno tomorrow, make a guess. (scorp508)
Before the head porting, my car did 109 mph with 300 rwhp on a cold day at the track. You may be a little more.
Old Aug 2, 2002 | 07:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For a 3,380lb Vette it looks like about 340-350hp at the crank; with your tranny maybe 290-300rwhp.
Anyway sounds close; good luck and don't foreget the wide band O2 sensor. Maybe he'll tweak your AFPR. :eek:
Old Aug 2, 2002 | 08:00 PM
vader86's Avatar
vader86
Default Re: Dyno tomorrow, make a guess. (65Z01)
~350 crank
are you tuning the car yourself and are you gonna use this dyno run to tune? or are you gonna send the data off to somebody like Ed Wright and have him tune it?
Old Aug 2, 2002 | 08:04 PM
scorp508's Avatar
scorp508
Default Re: Dyno tomorrow, make a guess. (vader86)
Well the tuning credit really goes to SloRVette. He will be the brains behind tuning it. I am SO new to modifying ECMs that I am at a severely steep learning curve. Right now I will mainly be watching and trying to learn how to interpret the data and how to correct for it.
Will will use the dyno with wideband O2 in conjunction to other diacom data I have on the car to start tweaking it.
No I'm a firm believer in NOT using mail order chips. Kinda like those mail order russian brides. Are you EVER sure of what they will send ya? Sure it might be blonde and voluptious...... all over! :eek: You'll get a chip "in the neighborhood" for what you have, but it will never be dead on as every car is different.
Old Aug 2, 2002 | 08:17 PM
Sharky Guam's Avatar
Sharky Guam
348 at the crank and 312 at the wheels. What's the prize for the member with the closest numbers? A chance to drive your car at the strip?
Good luck!
:cool: :cool:
Old Aug 2, 2002 | 08:19 PM
scorp508's Avatar
scorp508
Default Re: Dyno tomorrow, make a guess. (Sharky Guam)
If you're ever in the Boston area you already have an invite. :)
Hmmm.... prize, what should it be......
Old Aug 2, 2002 | 08:34 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Hey Scorp. This is kind of off topic but what do I need to do a TB Bypass tomorrow? I'd like to do a comparision with and without.
If you have the parts I'll compinsate you tomorrow. :D
Oh and I'm guessing 352 crank! :)
Old Aug 2, 2002 | 08:37 PM
scorp508's Avatar
scorp508
Ack... I don't know off the top of my head. Ask George, he has done his. I haven't done mine.
I'll use a 17% drivetrain loss figure though as always for the 4+3.
Old Aug 2, 2002 | 08:38 PM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: (scorp508)
Old Aug 2, 2002 | 08:48 PM
ZBRA's Avatar
ZBRA
What are your mods? I know you have a SR, but what cam, heads, etc..
Old Aug 2, 2002 | 08:53 PM
scorp508's Avatar
scorp508
Lingenfelter SuperRam Plenum & Runners (Not ported)
Lingenfelter SuperRam Intake Manifold (Not ported)
Lingenfelter 74219 Camshaft
Comp Cam Pro Magnum 1.6 Roller Rockers
General Motors 10088113 Aluminum Cylinder Heads (D-Port 88-91 L98 Heads)
- Ported & Polished
- Manley Pro-Flo 2.02" Intake Valves
- 1.60" Exhaust Valves
- 3-Angle Valve Job
- Lunati Double Valve Springs
- 10 Degree Titanium Retainers
- Comp Cam Valve Locks
- 7/16" Rocker Studs
- Heat Treated Pushrods & Guide Plates
- New Valve Guides
Sealed Power OEM Style Roller Lifters
Hooker 2149 Headers
Hooker 16720 Front 3" Y-Pipe
Flowmaster 1012 Rear 3" to 2.25" Y-Pipe
Flowmaster Mufflers
Main Cat 3" Test Pipe
AIR Pump Delete Kit
Crank Underdrive Pully
Descreened MAF
K&N Filter
Open Air Filter Lid
MSD Super Conductor 8.5mm Wires
Conrad Distributor Cap & Rotor (Cheap Autozone stuff)
Cheapo Ignition Control Module
Accel Supercoil Ignition Coil
Adjustable Fuel Pressure Regulator
22# Stock Injetors
ARP Fasteners
Fel-Pro Gaskets
Keep in mind the car is not tuned. The computer and fuel pressure are out to lunch right now. We MIGHT have a slightly better chip in it for tomorrow, not sure yet.
[Modified by scorp508, 7:54 PM 8/2/2002]
Old Aug 2, 2002 | 09:28 PM
red-y's Avatar
red-y
Estimate RWHP @ 326 - let us know - Good luck.. :cheers:
RocketSled's Avatar
RocketSled
I dunno. I ran a 14.1 at 99 mph up here (NHRA corrects to 12.5 at 114 I think), THEN took it to the dyno and was EXTREMELY disappointed in the results. :(
Timeslips: http://www.millerville.cc/images/timeslips.jpg
Dyno 1: http://www.millerville.cc/images/dyno2.jpg
Dyno2: http://www.millerville.cc/images/dyno1.jpg
Torque peak is about dead on if you figure 20% for my slushbox (382 RWTQ) but the mill's not pulling past 4500rpm, it should be good for a hp peak at 5200 or so.
The good news is, I get to find where the power is, the baaaad news is: I break 14's and the'll kick me off the track. :reddevil
Old Aug 2, 2002 | 09:33 PM
Sharky Guam
Thanks for the invite. Actually, I may be in Boston before the end of the year. My dad's sister lives in the area and I may give you a buzz to get a look at your car. I have been trying to collect enough parts to sort of duplicate what you have. So I am very interested in your dyno results. It looks like a very decent combination for a street and occassional strip car. Being the president of our local drag organization, I will see a lot of time at the strip. So naturally, I need a car that I can drive to the strip and occassionally play with on the weekdays. It is a pain to trailer the Vega to the track all of the time.
:seeya
Old Aug 2, 2002 | 09:35 PM
PoloGrnC4's Avatar
PoloGrnC4
Default Re: (red-y)
I've seen you run at the track Brian.. I'll betcha see 295 HP and 330 ftlbs.
good luck!
Old Aug 2, 2002 | 10:21 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Hehe, I wanna know what the hp is gonna be AFTER your baseline run when you tune it. :)
12.8 unsorted is. :cool:
To Dyno tomorrow, make a guess.
Old Aug 2, 2002 | 10:39 PM
scorp508's Avatar
scorp508
Me too. :D
Keep in mind that thta 12.89 run was spinning the tires a good first 100' or so with a lousy 2.1 60'.
Old Aug 2, 2002 | 11:07 PM
ZBRA's Avatar
ZBRA
318 rwhp
361 rwtq
since it isn't tuned. :cheers:
EDIT: Sad when you can't even spell "rwhp" right. :rolleyes:
[Modified by ZBRA, 9:08 PM 8/2/2002]
Old Aug 3, 2002 | 12:21 AM
rcolling's Avatar
rcolling
OK, here's mine. 320 rwhp.....
That is just to soothe my ego. I cannot break into the 12s with street tires.
