Surprise!
Old Nov 19, 2014 | 02:05 PM
DanielRicany's Avatar
DanielRicany
Default Surprise!
Well the day has finally come. The dyno results are in.
The car made a best of 344 rwhp and 343 rwtq.
Let me know what you guys think.
Old Nov 19, 2014 | 02:13 PM
don hall's Avatar
don hall
Old Nov 19, 2014 | 02:18 PM
STL94LT1's Avatar
STL94LT1
That"s impressive!
Old Nov 19, 2014 | 02:32 PM
Vic'89's Avatar
Vic'89
Default looks good
What's the setup again ?
Vic
Old Nov 19, 2014 | 02:34 PM
ch@0s's Avatar
ch@0s
Cool
Old Nov 19, 2014 | 03:26 PM
DanielRicany
Vic
1985 Corvette 350 CI. Miniram, 58 mm throttle body, flat tappet cam (224*/224* @ 0.050", 0.528"/0.528" valve lift with 1.6 RR, 112* LSA), hooker longtube 1 3/4" headers, Corsa true dual exhaust with h pipe, 1.6 comp cam roller rockers, AFR 195 Eliminator street heads, 10:1 compression.
Old Nov 19, 2014 | 03:57 PM
bjankuski's Avatar
bjankuski
Nice job!!
Old Nov 19, 2014 | 05:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I think that makes it faster and more powerful than any stock LS1 ever made. You said it wasn't. I/we said "get it dyno'ed" so you know, b/c SOTP doesn't mean ****.
Look what happened. Did a light bulb come on?
Old Nov 19, 2014 | 06:27 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Nice!
Old Nov 19, 2014 | 06:54 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I concur. It seems like this should have been posted as a resolution to that other (original) thread. Doesn't really address the perspection/concerns back then, does it?
Or state if a problem was found.
It's always nice to see/read resolution.
Old Nov 19, 2014 | 06:58 PM
GREGGPENN's Avatar
GREGGPENN
You might have left a bit of power (and torque) on the table (with the choice of that [TPIS?] cam with those heads), but it's a solid build that'll have great longevity. If you have a Dana 36 auto, it's also a choice match for longevity. GREAT distribution of power throughout the powerband too!
Did you install that cam "straight up"?
Old Nov 19, 2014 | 08:47 PM
DanielRicany
Yes I installed it straight up. And it's a 4+3 with a Dana 44.
Old Nov 19, 2014 | 09:01 PM
DanielRicany
I find it interesting how both peak hp and torque numbers are the same...
Old Nov 19, 2014 | 09:10 PM
Vic'89's Avatar
Vic'89
Cool , kinda similar to mine.
Now back that rwhp with some solid ET's and MPH.
Vic
Old Nov 19, 2014 | 09:20 PM
DanielRicany
Vic
I think you should race my car down the track. You seem to be good with squeezing every little thing out of the motor. Haha.
Old Nov 20, 2014 | 02:16 AM
cv67's Avatar
cv67
St. Jude Donor '05
See its not as bad as you thought although youve spent a lot of time on it
perhaps due the the torque curve not being "peaky" you just think its supposed to be faster or feel that way.
should be a solid 12 sec runner with no problem.
Old Nov 20, 2014 | 06:40 AM
bjankuski's Avatar
bjankuski
Base ls1 yes, 2002-2004 Z06 very close in power, and they have less weight.
To Surprise!
Old Nov 20, 2014 | 07:19 AM
DanielRicany
I think it has a few peak hp left in it. It got real fat up top. I think someone explained to me that the air/fuel ratios will vary dependent on the MAF flow at the time. On the street it was high 12:1 AFR. Different on the dyno. But in the right ball park.
Old Nov 20, 2014 | 07:57 AM
cv67's Avatar
cv67
St. Jude Donor '05
Next move up to a roller cam send me those heads/intake
Get ya up to 400+-
Honeslty next move would be to stroke it and do both youd have a rocket on your hands if you could tune it. Keep saving
Old Nov 20, 2014 | 08:00 AM
DanielRicany
Get ya up to 400+-
I'm done poking around with it. Until I blow it up at least. Then I'll do a 395 or 396 whatever it comes out to. I think it'll last a long time though. This motor has 106k on it.
