Code 36 help
Old Nov 3, 2015 | 10:06 PM
  #161
puzzigully's Avatar
puzzigully
Originally Posted by tequilaboy
The trick here is to determine what voltage the ecm is seeing during the burnoff to better understand why it is failing.
I agree - if only I could find someone local who has and can run an oscilloscope correctly!
What we do know is that the MAF voltage is greater than 1.46 volts since the signal is being limited to 23 gm/sec by the max maf vs rpm table in the log data.
It does look that way, but is that what the ECM is seeing?
I'm not convinced - see first comment.
We also know that a voltage greater than 95 A/D counts will set the code 36 failure. Since 95 A/D counts is approx. 1.9 volts, we can safely assume that your MAF voltage during burnoff is exceeding 1.9 volts.
Not sure I agree here as the ECM doesn't tell you WHY it failed (i.e. high voltage, low voltage, didn't see the burn off event at all etc), it just says it failed.
My local guy and an "expert" claimed the ECM wasn't seeing the "end" of the burn off event - and claimed that may be why it was throwing the code..
Now if you would log the same event using TunerPro with an appropriate adx file and monitor the unlimited airflow signal during the burnoff and relate the value back to the appropriate MAF flow vs voltage table (likely the #2 MAF table), we could indirectly estimate the MAF voltage during burn off.
I agree. It's imperative that I know WHY it's failing.
I'll have another crack at getting Turnerpro working...
I really don't want to be lazy and just disable the reporting......but it's sooooo easy and tempting!!
Old Nov 4, 2015 | 10:24 AM
  #162
tequilaboy's Avatar
tequilaboy
If the voltage was failing on the low side during burnoff (< 20 A/D counts or approx. 0.40 volts), the MAF signal would reflect this and would be approx. 5 gm/sec.
Since we see 23 gm/sec, we know that the MAF signal is being limited to 23 gm/sec and that the voltage is greater than 1.46 volts.
Old Nov 4, 2015 | 09:44 PM
  #163
puzzigully's Avatar
puzzigully
Hopefully i can log it and see the burn off using your file (much appreciated) on tunerpro.
Old Nov 9, 2015 | 05:49 AM
  #164
puzzigully's Avatar
puzzigully
With Soooooo much assistance from Tequilaboy, finally got Tunerpro to work correctly, then I could actually log the burn-off taking place.
Cannot thank him enough
Both he and Cliff have been very helpful and patient..
Here is the screen shot of the logging
The burnoff level is 80 g/sec, which equates to approx 2.9V....above the 1.9V threshold.
The other MAF I had, showed a burnoff level of 79 g/sec - so pretty much the same.
As Tequilaboy said - trying another MAF is a "crap shoot"....so likely to either raise the burn off threshold to something like 3V or remove the reporting altogether....
I might just try one more MAF
Just to be sure.....
Be nice if I could find one in a car that isn't showing a code 36 error!
Old Nov 9, 2015 | 07:09 PM
  #165
WW7's Avatar
WW7
Your best bet might be to find a good used stock sensor instead of getting more of the rebuilt crap, at least then you would have a maf sensor that was within spec...WW
Old Nov 9, 2015 | 07:19 PM
  #166
c4cruiser's Avatar
c4cruiser
Some of the MAF Sensors being sold require a core to be returned. I just bought a MAF sensor as I was getting a Code 34 and the diagnostic chart in the FSM caused a Code 33 which indicated a bad MAF. There was a $40 core charge but I was able to bring in the old MAF so I didn't have to wait for a credit.
I did find brand new AC Delco MAF sensors (Amazon and RockAuto) but they were in the $900 price range, plus a core charge.
I would think that the only real way to find a good working MAF sensor would be from a parts car. And even then, you would have to test it to make sure it is OK.
Old Nov 9, 2015 | 07:27 PM
  #167
WW7's Avatar
WW7
If the op needs a broken sensor as a core I have one sitting on the shelf in the garage he can have free, just pay shipping.....I will never go back to the stock maf sensors now that I have one of the Blowerworks units.....My Blowerworks maf sensor only cost me around $350.00 to $400.00 including the new bin file, and a new Bosch unit is over $800.00....WW
Old Nov 10, 2015 | 01:03 AM
  #168
puzzigully's Avatar
puzzigully
Thanks for the offer - my expert actually broke my original one, so I have a core :/
I recall the MAF's were the same 85-89? Can someone confirm, google isn't playing nice.
Old Nov 10, 2015 | 07:09 AM
  #169
WW7's Avatar
WW7
All the places I looked listed the original Bosch sensor #101145 for the 86-87 Corvette, and the #101146 for the 88-89 Corvette.They may interchange but they are listed as different sensors....Some of the aftermarket sensors are listed for 86-89 Corvettes ,but it seems the 85 has a sensor specific to that year...I went to several sites and this information was consistant....WW
Old Nov 11, 2015 | 12:35 AM
  #170
Cliff Harris's Avatar
Cliff Harris
I know that there was a Delco MAF that put our a variable frequency vs. air flow. It was very inaccurate and didn't have much capacity, which is the reason to switch to the Bosch MAF.
For the record, my original '86 MAF has these markings on the bottom:
I like the "Durchfluss"...
I have wanted to take apart a MAF for a long time but I don't want to destroy the working spare that I have.
Old Nov 11, 2015 | 06:28 AM
  #171
puzzigully's Avatar
puzzigully
mine has the following numbers:
0 280 213 002
14 081 243
Wonder what they actually mean?
Seems as though there is some disagreement if a maf is good for 1986-1989 or if there is a different version for 1986/87 and 1988/89...
Old Nov 11, 2015 | 10:37 PM
  #172
puzzigully's Avatar
puzzigully
I've done some research and have gathered some information (reliable I hope)
MAF Part#'s
1985
OE: 10037437
Bosch: 0 280 213 002
Tomco: 20011
1986-87
OE: 14094712
Bosch: ?
Tomco: 20012
1988-89
OE: 10055877
Bosch: 0 280 213 004
Bosch: 0 280 213 009
Tomco 20013
so it seems my "original" MAF is actually from a 1985 and Cliff, yours is from a 1988-89.
Still haven't found the Bosch part# for the 1986-87 MAF yet.
But it seems that Tomco and several other suppliers seem to think there's enough of a difference to have 3 separate part#'s for 1985-1989.
So I'd be wary of any MAF claiming to be be suitable for 1985-89 or even 1986-89
reference:http://www.tomco-inc.com/Catalog/maf%20sensors.pdf
There was an ebay listing of a NOS 1987 MAF here:http://www.ebay.com.sg/itm/86-87-NOS...-/391150609464
But the pic isn't good enough to read the Bosch numbers
Old Nov 12, 2015 | 12:34 AM
  #173
Cliff Harris
MAF Part#'s
1985
OE: 10037437
Tomco: 20011
1986-87
OE: 14094712
Bosch: ?
Tomco: 20012
1988-89
OE: 10055877
Tomco 20013
That's the MAF that was on my car when I bought it in 1985, so it's highly unlikely that it's a later version.
Bosch's number system is: "0 280" is for a MAF. The other numbers are the actual model number.
Old Nov 12, 2015 | 12:55 AM
  #174
puzzigully's Avatar
puzzigully
Tough to argue with you Cliff.
Unlikely someone went to the future and brought back a MAF to fit on your car
Old Nov 20, 2015 | 11:12 PM
  #175
puzzigully's Avatar
puzzigully
Here's a thought.
What is your opinion of testing the MAF off the car?
By that I mean, apply 12v, see the burn off wire heat up, then read the output on a multimeter.
I'm guessing you'd need to apply 12v across terminals D and A, then read with the multimeter across terminals C and B
Thoughts?
Old Nov 21, 2015 | 01:23 AM
  #176
Cliff Harris
I would connect terminals A & B together when you do that test to prevent any ground loops or other weirdness.
I sort of did that test when I made this picture:
I didn't measure the MAF output when I did that -- I just wanted to get a picture of a glowing wire.
Old Nov 22, 2015 | 05:55 PM
  #177
puzzigully's Avatar
puzzigully
Well now I'm really confused! (as if that's even possible to be more confused!)
Just measured the output......1.9V????
Not the 2.9V the Tunerpro says the ECM sees???
Starting to wonder if a bad earth may cause an artificially high voltage reading??
The 1.9V is tantalizingly close to a "pass" for the test.
For the record, I had to put +12V on both D and E to get the burn off to work.
To Code 36 help
Old Feb 1, 2016 | 04:50 AM
  #178
puzzigully's Avatar
puzzigully
To those playing along at home......
After trying two different ECM's, 4 different MAF's, 4 different relays, learning how to access the ECM using two different software packages, MOATES hardware, I know WHY I'm getting the Code 36, but no way to remedy the problem....
All the data, no matter the combination, shows that the burn-off voltages are always above the threshold to pass the test. Thus the Code 36 gets set.
I found a local (here in Australia), who could access the chip and turn off the reporting of the code and thus no SES light due to Code 36.
Good thing about this is that any other code will light up the SES light, that previously may have been hidden by the SES being caused by the Code 36.
I thought about expanding the test parameters for the MAF burn off test, but the local guy wasn't too confident in doing so, so took the simple way out!
As of today, been driving it around town, getting out, turning it off, back on again numerous times.......NO SES light and no Code 36!!!!!!
Old Feb 1, 2016 | 10:27 PM
  #179
xrav22's Avatar
xrav22
I would replace the longest possible length of wire and the connector. Your wire could be broke inside the cover and you will never know.
I would first clean the connector (not with a wire brush unless battery is disconnected!) super good to maf. I think they sell maff connectors. I used to have every code and solved a lot by cleaning connectors and replacing some wires. Also as the plastic coating shrinks the wires will touch so I use a pencil once in a while to keep em separated. Good Luck
Old Apr 25, 2018 | 10:37 AM
  #180
larryfs's Avatar
larryfs
I just went through the code 36 nightmare. Long story short, I put the OEM MAF back in, and I haven't gotten the code since.
I'm pretty convinced the aftermarket MAF's are not 100% compatible with the burn off circuit.
Not even sure if GM still offers OEM parts, as my dealer told me it has a MAP sensor, not an MAF.
