Code 36 help
Old Nov 23, 2014 | 11:11 PM
AJ123's Avatar
AJ123
Default Code 36 help
New Maf
Tested my MAF on a friends 87 vet he pulled no codes. Put his on mine still came back 36.
Messed with wires cleaned plug. No go. I start by clearing code. Will start up and run all day with no code. Shut it off re start and the code comes back up. I have already replaced the relays.
Will have a new plug here Friday. I wasn't going to pay 50 bucks from CARQUEST.
Any suggestions
Old Nov 24, 2014 | 01:03 AM
AJ123's Avatar
AJ123
Originally Posted by AJ123
New Maf
Any suggestions
bump
Old Nov 24, 2014 | 01:44 AM
Cliff Harris's Avatar
Cliff Harris
Error code 36 is a BURNOFF fault. That test is only done AFTER the ignition is turned off. The burnoff relay applies 12 volts to the MAF sensor wire and the ECM checks the output from the MAF while this is happening. If the output is not within the parameters it sets error code 36.
There are two MAF relays mounted on the firewall behind the battery. One is the MAF power relay and the other is the MAF burnoff relay. They have the same part number and you can swap the connectors and see if the problem still exists (this is true for '87 and later cars. On the '86 the two relays ARE different). If the problem goes away then the burnoff relay is bad.
Last edited by Cliff Harris; Sep 4, 2017 at 03:57 AM. Reason: Added clarifying wording.
Old Nov 24, 2014 | 06:31 AM
AJ123's Avatar
AJ123
I replaced both of the relays on the firewall behind the battery already.
I have switched the new relays no luck.
Old Nov 25, 2014 | 03:04 AM
Cliff Harris
Do you have 12 volts on the MAF (pin E) when the ignition is on? That's the power for the MAF that comes from the MAF power relay.
Does the output on pin C change with engine RPM? It should range from near zero at idle to 5 volts at high RPM (and high air flow).
Do you measure 5 volts on pin C of the MAF connector when it is unplugged? That 5 volts is a reference voltage that comes from the ECM. This test checks the wiring between the MAF and the ECM.
Old Nov 25, 2014 | 09:38 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
To fully clear the codes u need to disconnect the batt neg (i disconnect both + and - cables) then step on the brakes for 10 sec. Then u can reconnect the batt. Pulling the ECM fuse sometimes doesnt get it reset due to capacitors in the sys.
Hope this helps.
Old Nov 25, 2014 | 04:43 PM
c4cruiser's Avatar
c4cruiser
What does stepping on the brake pedal do with regards to clearing codes? Especially when you state you disconnect both battery cables.
For the OP, here's the '87 FSM procedures for troubleshooting/solving a Code 36
Old Nov 25, 2014 | 09:23 PM
cardo0's Avatar
cardo0
Hope this helps.
Try reading Automotive Diagnostic Systems by Keith McCord page 27.
Old Nov 25, 2014 | 10:13 PM
AJ123's Avatar
AJ123
I am leaving for Beach tomorrow and won't have time to check till Sunday unless I get rained out.
Thanks Cliff
Steve
Old Nov 25, 2014 | 10:25 PM
AJ123's Avatar
AJ123
I have been using this chart . Had the Battery out over night while replacing MAF burnoff relay . Dropped wrench inside fender wheel had to take side panel off to get to wrench.
Still 36 after running engine turning off after awhile next startup 36 again
Old Nov 26, 2014 | 12:20 AM
Cliff Harris
That's one of those Internet myths that gets passed around and sounds sorta valid so it gets repeated over and over again. I have also heard to turn on the headlights. Another one I've heard many times is to leave the battery disconnected for 10 minutes, 30 minutes, etc.
You don't need to do either of these things. Just disconnect the negative battery cable for a second or so and you will be OK. For an interesting analogy that applies: how long does your computer stay on after you turn off the power?
Old Nov 26, 2014 | 02:26 AM
cardo0's Avatar
cardo0
Are u saying the ECM doesnt have capacitors inside the circuits? How would u discharge them? It takes 10 seconds for the LED on my most of pwr supplies to extinguish - where does that power come from?
I learned this from the brake malfunction lite on my truck as the means to reset it. It was worth the 10 sec effort.
Old Nov 26, 2014 | 04:07 AM
Mark8801's Avatar
Mark8801
Cliff is right. All that needs to be done to clear codes on this old GM stuff is disconnect the battery for a few seconds. (resets the clock on the radio that fast also)
A couple weeks ago was the first time I ever heard of the "turn on a light" to drain the current myth. It sounds good but it's not needed.
Old Dec 14, 2014 | 12:51 PM
AJ123's Avatar
AJ123
replaced relay plugs an sensor burn off replaced plug to maf sensor maf sensor replaced repaired wires with cracks. Same code still comes. Used great advice given by Cliff
will try for another week and if no luck will take it to my friends shop
hate to admit defeat
Old Dec 15, 2014 | 12:35 AM
AJ123's Avatar
AJ123
New Maf
Any suggestions
bump
Old Dec 18, 2014 | 08:38 PM
puzzigully's Avatar
puzzigully
I have almost the exact same problem on mine.
I had a workshop work on it for a couple of days, replaced relays but no fix.
I've shipped it back to Australia and intend to work on it here.
your problem sounds like a wiring issue if your MAF didnt throw any codes on another vehicle.
I'm thinking that there may be enough of a resistance in a wire sending a signal to the ECM that it thinks it has a problem.
To me you need to confirm two things:
1. did the burn off actually happen
2. after burn off , did a signal go back to the ECM?
On the surface, this should be an easy fix, but it seems like its all too common on cars of this era.
something has to be marginal - and the wrong side of marginal..
My first step is to follow the trouble shooting guide to the letter - then measure resistances in all the relevant wires.
Good luck
Old Dec 19, 2014 | 01:46 AM
Cliff Harris
Power supplies have massive capacitors in them so they're able to respond to sudden high loads. ECMs don't.
I measured the voltage on the power wire going into my ECM and disconnected the battery. The voltage went to zero in less than one second:
To Code 36 help
Old Dec 19, 2014 | 05:23 AM
puzzigully's Avatar
puzzigully
Cliff,
Awesome information right there!
Thanks for posting.
Old Dec 19, 2014 | 09:33 AM
AJ123's Avatar
AJ123
Well this should be a simple problem to solve and it hasn't turned out to be simple. Monday into my best friends shop.
Old Dec 19, 2014 | 02:17 PM
Dt86's Avatar
Dt86
Have you tested your "new" relays to make sure they are good? I got a bad one once.
