Blew it up
Old Aug 3, 2002 | 06:58 PM
Finland's Avatar
Finland
Default Blew it up
Yup, now it's a fact !!!
Blew my engine yesterday on the strip!!
Sprayed as usual and suddenly it all went bad, started with that so feared missfiring sound and then the power dissapeared totaly.
Shutting down the engine I could listen to the scary sound of metal rattle. So, no worrys about spending time on the beach for a while. I suspect, at least, broken valves, pushrods and piston. Maybe now it's a good time to replace some other stuff too ?? Anyway, all has to come out.
I jus feel like...... :U :cry
Old Aug 3, 2002 | 09:32 PM
black bart's Avatar
black bart
Default Re: Blew it up (Finland)
Sorry to hear that but it reminds me of old saying when you play you have to pay
Old Aug 3, 2002 | 10:29 PM
YellowFvr's Avatar
YellowFvr
Default Re: Blew it up (black bart)
strange....a L98 with msd digital 6 and only a 150 shot would be ok, i thought.
Old Aug 3, 2002 | 10:48 PM
Finland's Avatar
Finland
So did I to, but nope.
It's gonna be REALLY interresting to open that sucker up and see what she's been eating...... :mad :mad :mad
Old Aug 4, 2002 | 01:55 AM
BubbleHead's Avatar
BubbleHead
Default Re: Blew it up (YellowFvr)
I like staying with a 125 shot or less. Anything more then 125, I hear more horror stories.
Sorry to hear of your misfortune. Now you can build it bigger and badder! :D :yesnod:
Old Aug 4, 2002 | 01:23 PM
red-y's Avatar
red-y
Do you have an automatic or stick? Full throttle switch, window switch?
What was your chip doing to your timing/fuel? 150 shot is pushing it as you know. Sorry to hear the bad news.. :eek:
Old Aug 4, 2002 | 04:35 PM
Finland's Avatar
Finland
Default Re: Blew it up (red-y)
Auto, WOT, retarded timing by 7 degres. Fuel pressure high enough.
I have been spraying through a few bottles without any problems. Maybe I got some really bad gas, who knows ??
Anyway, I'll keep you posted about the damage done as soon I pull the engine (starting on tuesday eve.).
If it's really messed up bad I'll go for the 383, miniram and a nice Lingerfelter :yesnod: :lol:
Old Aug 4, 2002 | 04:44 PM
red-y's Avatar
red-y
[QUOTE]Auto, WOT, retarded timing by 7 degres.
7 degrees seems high. What is your chip doing?? :smash:
Old Aug 4, 2002 | 06:00 PM
Finland's Avatar
Finland
OK for the retard, I agree that 6 deg. should be better ( 2 deg per 50 hp = 6) just keeping it a little over the top.
Actually I'm not too sure about the chip. The guy that programmed it told me that it would be good for 150 shots with the sig mods :confused:
I'm still leaning on the bad gasoline issue. Never bought any soup from this particular gas chain before :eek: And when I do buy, BOOM !! :mad
[Modified by Finland, 12:03 AM 8/5/2002]
Old Aug 4, 2002 | 09:27 PM
red-y's Avatar
red-y
So Sorry..I hope mine does't blow, it would not be good for the marriage. :eek:
Old Aug 4, 2002 | 11:27 PM
RatRacer's Avatar
RatRacer
A 150 shot is too much for straight pump gas. I run 30-50% race gas or 20-30% Toluene when I juice now. Regular plug inspections are mandetory too.
Old Aug 5, 2002 | 01:39 AM
Finland's Avatar
Finland
Default Re: Blew it up (RatRacer)
Do you use the mix only when you are spraying, if not, how does the engine cope with this fuel mix.
What about the injectors, do they get enough of lubrication :eek:
What about the eprom, any suggestions ?
[Modified by Finland, 2:14 PM 8/5/2002]
Old Aug 5, 2002 | 11:55 AM
RatRacer's Avatar
RatRacer
Toluene is already a major component in gasoline. Adding a few gallons (20-30%) will not harm your engine at all. In fact, it is an excellent injector cleaner. The best part is Toluene is 114 octane.
Old Aug 5, 2002 | 02:18 PM
krivera's Avatar
krivera
sorry about the blow up!
Old Aug 5, 2002 | 06:46 PM
black bart's Avatar
black bart
I posted info about home brew gas last year here is the link. http://forums.corvetteforum.com/zerothread?id=156565 :cheers:
Old Aug 5, 2002 | 11:59 PM
RatRacer's Avatar
RatRacer
That's a good link. I've seen that recipe before.
I don't add any lubricants or cleaners to the mix though. I figure there are already the necessary additives in the pump gas. I run cats and I'm afraid that marvel mystery oil and/or tranny fluid might foul them up. I don't know for sure. I've run a lot of straight Toluene with no problems though.
Old Aug 6, 2002 | 05:20 AM
Finland's Avatar
Finland
Just came home from the shop.
Pulled the heads and had a brief look on the damage and felt kinda dizzy.
4 pistons gone bye bye, pushrods looks like serpentines and too many valves broken, and thats just for starters, heaven knows what the bottom end looks like.
I'm gonna get drunk now and throw out my tv set or something....
:U :boxing :mad
To Blew it up
Old Aug 6, 2002 | 12:31 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Sounds like maybe the timing chain broke.
Old Aug 6, 2002 | 08:44 PM
red-y's Avatar
red-y
Damn - I will have a beer for you also.. :cheers:
Old Aug 16, 2002 | 11:28 AM
Finland's Avatar
Finland
Well, pulled the engine out and now tearing it apart.
Any good ideas on what kind of pistons I should use that can handle my setup ??
Actually it looks like the only damage made is some broken pistons (completely hollow now) and some broken valves. Fortunately the bottom end looks to be undamaged and no scratches in the cylinders....
I really don't want this to happen again so I need some kind of reinforced pistons and rings and probably i'll go for stronger valves to...'
Comments please......
[Modified by Finland, 5:29 PM 8/16/2002]
