Automatic transmission issue
Old Dec 27, 2014 | 04:05 PM
rickvano's Avatar
rickvano
Default Automatic transmission issue
I have a 96, LT1. When I bought it, three bearings had been spun on the crank. I knew it so I didn't pay a lot. The car has 57,000 miles on it and was in otherwise great condition. Well I finally got the motor done and back in and after a little break in period in the garage, it was time for a spin. 1st gear, 2nd gear, out of second, no 3rd! I revved it and let off and it shifted hard into 3rd. I didn''t want to do any damage to the tranny so I headed back to the garage. Anybody seen this before? What should I look for? The trans oil has been changed-- no difference. I did take it for one more spin and couldn't get it to shift into third without hitting 4000 rpm. I never did get it into 4th. I've tried manually shifting as well. Thanks in advance!
Old Dec 27, 2014 | 04:09 PM
pcolt94's Avatar
pcolt94
Is the TV cable set correctly?
Old Dec 27, 2014 | 04:18 PM
rickvano's Avatar
rickvano
TV cable? I'm a novice LOL. Tell me what it is and I will adjust it. I have a complete service manual.
Old Dec 27, 2014 | 04:28 PM
aj1988's Avatar
aj1988
Look on the drivers side by intake runners. You should see a button attached to one of the cables. I think (memory not like it used to be) you push the button in and then either have someone inside push peddle all the way open, or just move throttle by hand. This should set cable.
If anyone else reads this and I am wrong PLEASE post correction. It has been years since I have done this.
Also, mine is L98 so it may be different.
Old Dec 27, 2014 | 04:29 PM
arbee's Avatar
arbee
1996 - no TV.
Old Dec 27, 2014 | 04:35 PM
pcolt94's Avatar
pcolt94
The TV cable is the "throttle valve" cable that runs from the throttle (throttle body) to the transmission. It is sometimes called the kick down cable where as you put your foot down (from a high gear) on the accelerator, the transmission will downshift.
I thought that if the cable was radically misadjusted, it may keep the transmission from up shifting
However the transmissions from 94 and up are electrically operated and on second thought it may not use the TV cable. So I hesitate to send you in a wrong direction. Need to rethink this.
Old Dec 27, 2014 | 04:40 PM
rickvano's Avatar
rickvano
That's okay. But you are right. It doesn't have a TV cable, just a single cable from the pedal to the ASR and then one to the throttle.
Old Dec 27, 2014 | 05:06 PM
pcolt94's Avatar
pcolt94
I would check with a scanner to see if there are any OBD2 codes that come up for the transmission.
The PCM tells the transmission what to do. Since you just got the engine rebuilt, I would check all electrical connections to the transmission. If it does not get a signal to shift the solenoids, it probably will not shift. The PCM connections are part of the loop also.
Would be nice to know if the transmission was OK before the engine went out.
Problem can be electrical, to a stuck valve body or solenoid in the transmission. Lots of places to point at.
Old Dec 27, 2014 | 07:05 PM
arbee's Avatar
arbee
It is unfortunate that people still continue to call the TV cable a "kickdown cable". That is not it's purpose in being. It is critical that this cable be adjusted correctly. Even if this cable is out of adjustment, it still will most likely drop down a gear when heavy acceleration takes place. People who think this cable has done it's job in doing so are oblivious to the fact that they are destroying their trans little by little by a poorly adjusted TV cable.
Old Dec 27, 2014 | 11:38 PM
rickvano's Avatar
rickvano
I'm always amazed at the quality and why of information I get on the forum. Thank you all.
I'm getting a code scanner. I'll keep you posted. Thanks again.
Old Dec 28, 2014 | 11:26 AM
pcolt94's Avatar
pcolt94
I am actually in the process of doing an upgrade on my OBD2 scanner equipment. if you can afford it rather than getting a code reader, buy the best you can afford and over buy if you can.
Getting something that has live data and ABS (and good product support with a phone #) would be a good choice. You will be able to use it on any OBD2 vehicle you might get in the future. You know how fast electronics move, like buying a computer, buy for tomorrow.
Old Dec 28, 2014 | 03:37 PM
383vett's Avatar
383vett
As Someone may have mentioned , the ops transmission is a 4l60e which has no tv cable. The transmission's shifting is controlled. by the ECM. The transmission does have a limp home mode. Make sure the round connector plug in the passenger side is fully seated. It might have gotten yanked when the mote was removed.
Old Dec 29, 2014 | 08:16 AM
rickvano's Avatar
rickvano
Good idea, I'll check.
Old Jul 20, 2015 | 08:38 AM
24yrold&86conv's Avatar
24yrold&86conv
Did you get this fixed, what was the issue? I have this problem and need help.
Old Jul 20, 2015 | 08:41 AM
rickvano's Avatar
rickvano
Yes, it's fixed. Total rebuild of the tranny. Friction gone, seals gone, and a wonderful fragrance of burnt everything!.
Old Jul 20, 2015 | 08:52 AM
24yrold&86conv
How much did that run and what all did they do?
Old Jul 20, 2015 | 08:57 AM
rickvano's Avatar
rickvano
It was a fella who's retired and does it as a hobby. $1500. He replaced friction, seals and installed rebuilt torque converter, flushed and new fluid. Oh and he R&R'd. Pretty good deal and I know my numbers still match.
To Automatic transmission issue
