Axle Ratio
Old Dec 30, 2014 | 03:35 PM
american Iron's Avatar
american Iron
6th Gear
Default Axle Ratio
I have a C4 with a 436 cu.in. SBC and Tremec TKO 5 speed. I am setting up to race World Speed Trials. We are timed at the 1mi. mark and the 1 1/2 mi. I would like to know how to figure the best rear axle ratio to use. Any suggestions will be greatly appreciated.
Old Dec 30, 2014 | 05:52 PM
rklessdriver's Avatar
rklessdriver
How much HP and what MPH are you targeting?
How tall rear tire?
Any aero mods to the body?
Is there a speed trap at both or is the trap 1/2 mile long?
Will
Old Dec 30, 2014 | 07:29 PM
THE 383 admiral's Avatar
THE 383 admiral
Engine RPM limit
Old Dec 30, 2014 | 07:55 PM
THE 383 admiral
Quick slide calc 8500rpm 3.0gear 28.5 tire combo Could net 240 mph.
1600HP should be your goal @ 1 mile
Old Dec 31, 2014 | 09:39 AM
american Iron
6th Gear
Default American Iron Restorations
How tall rear tire?
Will
255/50ZR16 stock front openings faired 1mi. and 1 1/2mi. 700hp.
Old Dec 31, 2014 | 09:46 AM
american Iron
6th Gear
Looking for 215MPH in the mile or better Tremec TKO 5 speed Just need to know rear axle ratio to use. Should be turning 6600rpm. Thanks
Old Dec 31, 2014 | 10:05 AM
rklessdriver
You are going to have to use 5th gear overdrive in the TKO. Which ratio do you have?
Will
Old Dec 31, 2014 | 11:08 AM
american Iron
6th Gear
Will
1ST - 3.27
2ND - 1.98
3RD - 1.34
4th - 1.00
5th - .068 Thanks for the help. Dan
Old Dec 31, 2014 | 12:51 PM
WVZR-1's Avatar
WVZR-1
1ST - 3.27
2ND - 1.98
3RD - 1.34
4th - 1.00
This calculator might do well for your particular needs. I've done the math a couple times and have found no reason to dispute the "numbers". A plus to this calculator is that you can SEE the RPM drops between shifts that should help you calculate just exactly what you might want to change. A tire change vs. a rear gear change sometimes does wonders. Something that some don't realize is that the "RPM loss" between shifts isn't affected with flywheel weight choices. Flywheel weight considerations could be of some concern for you but that's a different conversation.
What do you actually have for a flywheel weight?
http://www.cargister.com/calculator-...l_ratio_teeths
Use actual tire dimensions and not the tire sizing option for accurate results.
Questions?
Old Dec 31, 2014 | 01:18 PM
american Iron
6th Gear
Questions?
29 lbs. don't have car to measure how high tire is.
Old Dec 31, 2014 | 01:50 PM
WVZR-1's Avatar
WVZR-1
I believe that most frequently that tire is mentioned to be 26" - try some calculators and then use maybe 97% for a rolling dimension to use in the calculator that I linked to. I like the flywheel weight and I'd think it a plus for MPH at the 1 and 1 1/2 mile runs. There may be other thoughts but MPH and longer than 1/4 mile results I like it. Are these standing or rolling distances? You may have mentioned and I just overlooked but I thought it easier to maybe ask than go back.
You want "rolling" dimensions to do this accurately NOT advertised height or dimensions. There's a couple ways to calculate "rolling" accurately.
Old Dec 31, 2014 | 01:59 PM
american Iron
6th Gear
Standing start at the World Speed Trials Loring A.F.B. July 23-26. In the Modified Sports Class. Thanks for the info. Dan
rklessdriver
That 255/50R16 tire is 26" tall....
A 3.54 rear gear is going to give you potentially 212 MPH at 6600 RPM.
A 3.45 is potentially 217 MPH.
Both in 5th gear of course.
http://www.csgnetwork.com/speedcalc.html
Will
To Axle Ratio
