Pulling The Engine
Old Jan 19, 2015 | 02:24 PM
shamdave's Avatar
shamdave
Default Pulling The Engine
I am pulling the engine on my 85. I decided to pull the trans with it. I can not get the damn drive shaft bolts to budge. Any ideas?
Also do i need to remove the center console to remove the linkage?
Any one in southwest Ohio wants to help Im buying the beer!
Old Jan 19, 2015 | 04:01 PM
John A. Marker's Avatar
John A. Marker
The bolts should not be too tight. Suggest PB Blaster on the bolts and let them soak.
If it was me, I would leave the transmission. Have your removed the hood to pull the engine or are you lifting and pulling to the side. I pulled mine to the side and left the transmission. Much easier.
Old Jan 19, 2015 | 07:21 PM
shamdave's Avatar
shamdave
I pulled the hood off and i can not get to the bell housing bolts any trick would be appreciated
Old Jan 19, 2015 | 07:25 PM
John A. Marker
I used box end that was offset and ratchet with extension with universal.
Old Jan 19, 2015 | 07:34 PM
shamdave's Avatar
shamdave
maybe ill give it a go again
was yours a automatic?
To Pulling The Engine
