trans fluid
Old Feb 13, 2015 | 06:57 PM
chazc4's Avatar
chazc4
Default trans fluid
6 speed, about to change the trans fluid what is the best fluid to use and how much one or two quarts
Old Feb 13, 2015 | 08:14 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Best fluid? That is probably up for debate.
Just don't put normal gear oil in your ZF-6
With that said, I am using Amsoil fluid.
http://www.amsoil.com/shop/by-produc...ont%2fmtf.aspx
Doing some quick searching:
https://www.corvetteforum.com/forums...eed-trans.html
https://www.corvetteforum.com/forums...ans-fluid.html
https://www.corvetteforum.com/forums...bmw-fluid.html
https://www.corvetteforum.com/forums...ion-fluid.html
https://www.corvetteforum.com/forums...best-lube.html
https://www.corvetteforum.com/forums...d-choices.html
https://www.corvetteforum.com/forums...id-change.html
Old Feb 13, 2015 | 08:22 PM
BigMac2395's Avatar
BigMac2395
I just did my transmission fluid on my LT4 car. I used the RedLine Shockproof Lightweight Gear Oil. I checked with Bill at ZFDocs and he said it was OK to use. Bill also told me that the plugs do not need any sealant just torqued to 26 pounds. 2.1 quarts of fluid. Have fun!!!
Russell
Old Feb 14, 2015 | 06:45 AM
chazc4's Avatar
chazc4
thanks for your help
To trans fluid
