4+3 Question, Help Please
Old Mar 7, 2015 | 03:38 PM
RobnLisa's Avatar
RobnLisa
Default 4+3 Question, Help Please
I have an 86 Z51 4+3, got the car for next to nothing so I figured I would redo it. Got it up on stands in the shop today and slid under it to check things out. Now I see my first problem, it appears maybe someone replaced the sideplate on the trans. I have reverse light switch, OD solenoid switch, and speed sensor......thats it, no 1st, 2nd or 4th gear switches. Now what do I do?
Old Mar 7, 2015 | 04:21 PM
whalepirot's Avatar
whalepirot
a P/O probably tired of the oft-misunderstood logic and rewired it through the console switch.. solely! You don't need the other switches unless you wish to have it function as it did originally.
Old Mar 7, 2015 | 05:40 PM
RobnLisa's Avatar
RobnLisa
The button on the shifter and lower switch were all missing so I purchased new ones. Hopefully it will work when I get it all replaced. Still scratching my head as to why the whole sideplate was replaced.
Old Mar 7, 2015 | 06:56 PM
c4cruiser's Avatar
c4cruiser
Maybe the side cover had cracks where the shifter forks went thru? Or it may have had bad shifter forks and a PO simply decided to replace it as a unit? The 4-speed portion is a Borg-Warner Super T-10 and the side cover and forks on the 4+3 version should be interchangeable.
On my '87, there is a 1st Gear switch, but no 2nd or 4th gear switches. The Reverse switch is under the Reverse shifter shaft on the O/D housing as is the O/D solenoid harness connector.
Old Mar 7, 2015 | 10:22 PM
tequilaboy's Avatar
tequilaboy
86 cars are unique and don't have any gear switches...1st and 4th gear ratios are detected by the ecm using n/v logic.
Old Mar 8, 2015 | 02:16 PM
DanZ51's Avatar
DanZ51
TequilaBoy is correct. My '86 had no such switches, only reverse on the trans. The OD had an engagement connection and housed the speed sensor.
Old Mar 9, 2015 | 10:56 AM
RobnLisa's Avatar
RobnLisa
Thanks for all the help!
Old Mar 9, 2015 | 03:54 PM
8a8mfh's Avatar
8a8mfh
I couldn't find this the other day http://www.5speeds.com/43table.htm
Old Mar 10, 2015 | 07:36 AM
RobnLisa's Avatar
RobnLisa
Thanks! That answers a ton of questions.
To 4+3 Question, Help Please
