Hip deep in cam swap which includes a valve spring upgrade too. Springs are being changed with heads on block. Havin a brain fart here.
I got #1 at tdc. What other pistons are also at the top of thier bores on this position. I know 4 of them are ar the top in this position. Then move the crank 180 degrees and the other 4 are at top.
Is it 1-7-4-6. Then turn crank 180 degrees and 3-5-2-8. Is this right?
You must be wondering why I'm thinking like this. Well, I'll be changing the springs for 4 cylinders in one position, the turning 180 degrees and changing the other 4.
Damn!!! Crappy overhead spring compressor can't grab dual springs. I shot a retainer into the air. I heard it hit the roof but I can't find it now. Guess I gotta buy a whole new set. And a worthy overhead spring compressor too.
..... there are two pistons at TDC at a time , for example ... #1 and #6 ... #8 and #5 ... #4 and #7 ... #3 and #2 ..... when the timing marks are lined up on the cam and crank gears #6 is on its compression stroke ........
C409 is correct, I was thinking tdc on compression and forgetting exhaust stroke. I use the same valve spring compressor that he linked from summit, but if the retainer is on top of the spring, that should be compressing both springs not the tool.
10-4. I just received shipment of that very spring compressor.
I'm sure this has been seen a bazillion times but here is my progress thus far. My brother has loaned me the LT1 specialty tools for crank hub and optispark.
