Best gear ratio.....
Aug 12, 2002 | 10:21 AM
'94 ZF 6spd. K&N, lid, wires, B&B Exhaust, and LT4 HotCam. What ratio would be the best for a gear swap?
I've heard many people using both 3.73's, and/or 4.09/4.10/4.11's
Who's got what and what do you like/dislike about your choice? Also, what gear and RPM do you pass through the traps at? And what RPM do you pull at say 80mph on the highway?
[Modified by Hi-psi, 9:21 AM 8/12/2002]
Aug 12, 2002 | 10:50 AM
There is no "best" gear ratio, it all depends on what you like. What do you want out of your swap?
Aug 12, 2002 | 11:01 AM
Re: (scorp508)
Based on other's experiences, what ratio(s) work "best" with this or similar combinations.......
Aug 12, 2002 | 11:32 AM
Re: Best gear ratio..... (Hi-psi)
Do you have microsoft Excel? I've got a spreadsheet worked up that will tell you the answers to all of your questions. You can just punch in a new gear ratio and it recalculates. It will also work for tire size, etc. Just fill it out and look at the numbers.
Aug 12, 2002 | 11:39 AM
Re: Best gear ratio..... (Nathan Plemons)
Nathan,
Please send that file this way!
Neal
Aug 12, 2002 | 11:43 AM
Re: Best gear ratio..... (Arisa)
This site is VERY helpful for all of you number crunchers........
http://www.bgsoflex.com/auto.html
Aug 12, 2002 | 11:45 AM
Aug 12, 2002 | 12:23 PM
I just had Dana 4.10's installed last week. I am turning around 2000 rpms at 70 mph.
Aug 12, 2002 | 12:25 PM
Re: Best gear ratio..... (STL94LT1)
4.10s
Aug 12, 2002 | 12:28 PM
How much did they affect the performance of the car? Either seat of the pants or track?
Aug 12, 2002 | 12:33 PM
Haven't been to the track, but with the original GSC's first and second gear are up in smoke. Also, sixth gear is finally usable.
Aug 12, 2002 | 01:29 PM
4.10s took 2/10s off at the track. I go through the traps in 4th gear
Jim Mason
'96 Grand Sport #007
Aug 17, 2002 | 08:13 PM
i have 4.09 in my car. its great for street driving. auto cross it seems like i shift alot on the low speed events..if you do that, i wuld reccomend a 3.73
Aug 17, 2002 | 11:29 PM
Hey that spread sheet sounds neat, can you send me it?
