how do I fix this
personally, and I've used JB Weld myself, but since you'll be working upside down, I'd try a thicker metal reinforced "putty" style epoxy.
When my harmonic balancer ring walked into my timing chain cover and ground a hole in it I used JB Weld to seal the hole. It lasted 10 years until I finally replaced the cover:
I think ill look at that oil adapter and filter and see how I feel about trying that.
At least its not dripping now and maybe there is something else causing the smoke off the exhaust under the car. Its definitely oil and see a puff come through the center vent area once in a while too.
The valve covers were loose and were tightened just a little,probably should check them.
This would be the only alternative (which has been mentioned) IF the grease failed:
http://67-72chevytrucks.com/vboard/s...60&postcount=1
Simple fix buy an oil cooler, you can see in the picture the gasket will seal as it goes right to the outside.
http://www.ebay.com/itm/GM-CORVETTE-C4-TPI-OEM-OIL-COOLER-USED-/400699908584?hash=item5d4b9361e8
The valve covers were loose and were tightened just a little, probably should check them.
looking at your original pic, you definitely have some additional leaking issues. could be any or all of the following - valve covers, intake gaskets (front and/or rear china wall, oil pressure sensors (behind the distributor). might even have some oil pan issues. since you seem to have the filter issue solved, next, tackle the VC's. invest in some new quality gaskets - baby steps, baby steps, baby steps, AND follow the K.I.S.S. approach....
to reiterate post #40,
drill, tap, grind, weld, braze, epoxy, oil coolers, remote filters, more gaskets, bigger gaskets, etc, etc, etc...
GM Corvette C4 TPI Oil Cooler Used | eBay
have you looked at the pics of this oil cooler? it looks to be a POS. if that thing didn't leak, it would damn near surprise me! take a good look at the upper and lower sealing surfaces. let's assume it was a quality used part -- now lets install it, and hopefully we won't have any issues bolting to the filter location. first of all, you need a pipe to hose nipple that screws into the LH lower block. hopefully we can get the old pipe plug out without causing any other damage. after all, that things been screwed into the cooling system water jacket for some 25 years. next we need a short (outlet) hose to connect the oil cooler, and throw in a couple screw clamps. next we need the inlet hose, and the pre-formed metal tube that runs along the LH side of the oil pan, along the bottom of the timing chain cover, and works it's way up to the upper right side of the engine. BTW, we need all the additional clamps and hardware that secures the metal tube to the oil pan. at the upper side of the engine, now we need a rubber "tee" that ties this oil cooler tubing into the heater hose, along with a bunch of additional hose clamps. hopefully, we won't have any installation problems and additional leaking issues. seems like you'll need a bunch of additional pieces-parts to install this oil cooler! of course, one could do a "bubba" installation - run a single piece of heater hose from the cooler to the heater hose and buy a bunch of hardware store pipe fittings, and secure everything with a bunch of tie-wraps!
while an oil cooler is a great idea from a performance standpoint, it's overly complicated from a repair standpoint. "simple fix" -
- no flames, but IF SOMEONE ASKS YOU WHAT TIME IT IS, DON'T TELL THEM HOW TO BUILD A CLOCK (by using one part)!
sorry, just ranting...
http://api.viglink.com/api/click?for...Bpostcount%3D1
That will eliminate .0002% of that engines oil leaks.
And I'm sure that a through cleaning with brake cleaner will eliminate any oil film....and if that isn't enough...do what commercial welders do, apply some heat, it doesn't have to be a lot, industrial heat gun, etc. enough to drive any oil from the pores of the metal.
In all honestly, this little divot in the sealing surface isn't that big of deal...but I would NOT tap and drill, especially working upside down with a hand drill and hand grinder, one slip up and ... well that's how little problems become big projects .
My head explodes trying to determine what advice is the best still.
Now todayt someone I talked with says he can weld it and finish it, uses some kind of trade secret welding rod to keep from causing damage to cast iron and hes been doing it for 20 years. Hes certain he can do it. But the thought of my car catching on fire or more damage has me nervous.
How much will he charge for this secret repair?
Folks above have good fixes for certain situations.
Nothing beats going back to basics and find out how many places the engine is leaking oil. Must clean all areas that are oily, not a easy task. Then watch carefully which areas get oily first, etc.
The gasket seal is all the way out to the rust line. You might have a raised edge that could be dressed down. But the way I see it...A new filter is not going to leak. Find the real oil leak and forget about that filter leaking.
