86 EGR pipe insulation. .....
Old Apr 22, 2015 | 06:26 PM
desertmike1's Avatar
desertmike1
Why are they wrapped in the first place?
Old Apr 22, 2015 | 07:08 PM
Joe C's Avatar
Joe C
might be a safety issue....
Old Apr 22, 2015 | 08:12 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
hot exhaust gases pass through that tube, the wrap protects other components from the heat.
Old Apr 22, 2015 | 10:33 PM
pezter22's Avatar
pezter22
I bought the upper and lower heat shield from Corvette Central. Pretty reasonable price and attach with velcro.
http://www.parts123.com/corvettecent...050f&ukey=9050
Old Apr 23, 2015 | 01:08 AM
Cliff Harris's Avatar
Cliff Harris
One of the main themes of this thread is that the Velcro turns to dust from the heat. That's why people are looking for alternatives.
The best solution seems to be to use header wrap and then put the foil heat shield on top of it for looks.
Old Apr 23, 2015 | 02:33 AM
Dt86's Avatar
Dt86
When I swap intakes I will be doing that. Great advice!
Old Apr 23, 2015 | 08:28 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by 86V
Hi. Just got done doing a Engine refresh on my 86. Polished the plenum and runners, some cool red powder coated pieces for color.
What's sticking out like a sore thumb is the insulation on the EGR pipe. I bought some new stock tin foil type like the original, but a month later it looks like **** Already.
Does anyone here have any creative ideas or solutions? Since I have a red theme going I was going to buy a roll of red exhust header tape. What do you think? Any opinions, ideas would be most appreciated!
Remove the EGR pipe
Old Apr 23, 2015 | 08:44 AM
Joe C's Avatar
Joe C
Originally Posted by AGENT 86
damn - now that's different - kind of like it! I would however, paint the silver background in the VC emblem, yellow to match. anyway, pretty cool -
Old Apr 25, 2015 | 03:14 AM
86V's Avatar
86V
Remove the EGR pipe
Wow.......that looks awesome!
Can you believe I'm still waiting for that Red Tape to arrive!!?
Can I ask , What happened when you removed the EGR pipe? I mean its got to be there for a reason. GM engineers aren't that inept are they? To design something not needed?
Old Apr 27, 2015 | 08:51 AM
Cajun CB's Avatar
Cajun CB
Default It is Wrapped Because....
The pipe is near the temperature in the exhaust manifold. Wires like the temperature sensor wire and spark plug wires can come into contact with it and burn.
My car had both problems.
Old Apr 27, 2015 | 10:08 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by eutu1984
I think the organelles were sewn on.
you mean originals?
Old Apr 27, 2015 | 10:22 AM
desertmike1
I understand, yet there are many cars running around with out heat wrap on the EGR supply tube.. in fact I'm working on a V6 Nissan as we speak, it's EGR Supply tube is near the firewall, no heat wrap.
Interesting..
Old Apr 27, 2015 | 11:25 AM
  #33
86V's Avatar
86V
Still waiting.........
Old Apr 27, 2015 | 03:03 PM
  #34
Cajun CB's Avatar
Cajun CB
Interesting..
The C4 Corvette has a fairly crowded engine compartment. There are several wires that are close.
I ran mine without insulation until I burned (grounded) the EGR temperature wire and got a code. When repairing it, I noticed that a spark plug wire was scorched also.
I keep it wrapped now. Each car is different.
Old Apr 28, 2015 | 01:16 AM
  #35
Cliff Harris
If you have an early '86 with cast iron heads then you don't need the EGR tube. There is an exhaust passage built in to the heads and intake manifold.
Originally all '86s were supposed to have aluminum heads, so that is why the EGR tube is present on all '86 cars.
Old Apr 28, 2015 | 05:58 AM
  #36
eutu1984's Avatar
eutu1984
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
Old Apr 28, 2015 | 07:20 AM
  #37
hcbph's Avatar
hcbph
Far as I know the aluminum heads started off on the convertibles in 86, early coupes (86's) definitely had cast iron heads from what I've seen. Don't know if all were switched to aluminum by the end of that years run or not. AFAIK starting with 87's they all had aluminum heads.
Could be wrong but don't think so.
To 86 EGR pipe insulation. .....
Old May 1, 2015 | 07:22 AM
  #38
86V's Avatar
86V
My 86' is a Late one (bought it in Sept'86) so it has the Aluminum heads.
The Wrap finally arrived. took 2 weeks........
I'm going to try the opposite first. I'm going to put on my lame tin foil wrap then put the red header tape over it and see how it looks. Nothing ventured , nothing gained..........
Old May 1, 2015 | 07:36 AM
  #39
86V's Avatar
86V
Interesting read........thanks.
I would think introducing the hotter exhaust was a No No for performance ......I wonder Why is it necessary for the aluminum over the Iron?
Old May 1, 2015 | 06:26 PM
  #40
86V's Avatar
86V
Here she is:
It looks a little bunched because I installed it over the old shield. I could have gotten a tighter wrap without it, but the purpose is to insulate so I took function over looks. I painted it with some 900* brake caliber paint straight to the pipe and in 1 long drive it was burnt right off. So I'm not taking chances, that's one hot little pipe!! I hope the color lasts on the header tape.
