Started by itself
Old Apr 29, 2015 | 01:06 PM
kbone077's Avatar
kbone077
Default Started by itself
I have a 1989 and while watching a movie at about 11:15 in the evening I heard my car start up. It has no remote start of any kind. After retrieving a firearm, flashlight and the keys I quickly went outside. Both doors were locked there was no key in the ignition but the car was sitting there idling away. I unlocked the door and put the key in and turned it to the on position and shut it off. Nothing happened. I then turned it all the way to start. The starter tried to engaged but grinded so I let off and then turned the key to off and the motor shut off. I have to say I have never seen a car just start up on it's own and just sit there idling. Anyone have any ideas? Should I just start calling the car Christine?
k
I forgot to add that when I entered the car the security light was flashing. That was the only unusual thing I noticed besides the car itself running.
Old Apr 29, 2015 | 03:17 PM
Roys92BlackRose's Avatar
Roys92BlackRose
If it happens again, get in and see where the car takes you!
Seriously though, that's crazy. Never heard of that before, on any vehicle. Maybe an intermittent short to the starter, or a faulty ignition switch. Whatever it is, not good. Good luck.
Old Apr 29, 2015 | 04:10 PM
WW7's Avatar
WW7
This doesn't sound possible at all....The key has to be on for a car to start, and unless the ignition switch makes contact the car can't start on it's own...Someone is screwing with you, or your screwing with us.......WW
Old Apr 29, 2015 | 04:19 PM
kbone077's Avatar
kbone077
Trust me I am dead serious. As impossible as it sounds it happened as I said. A buddy of mine came over and felt the motor. At first I thought I think I know what a running motor sounds like and then thought I wouldn't believe it either. I myself have never seen something like this happen ever and not sure how power could have got to the motor and starter without a key.
Old Apr 30, 2015 | 12:26 AM
Cliff Harris's Avatar
Cliff Harris
Somebody put a remote start system on the car?
Old Apr 30, 2015 | 01:24 AM
BOOT77's Avatar
BOOT77
Either someone tried to steal it, a buddy is messing with you or it has a remote start form a previous owner you don't know about.
Old Apr 30, 2015 | 01:45 AM
crowz's Avatar
crowz
Either it has a remote start you don't know about from earlier owner or aliens.
Old Apr 30, 2015 | 10:13 AM
suicidejockey's Avatar
suicidejockey
2 questions- 1)was the car sitting outside. 2) was it raining?
I ask because 1 of the vehicles I currently own had a problem with water intrusion. It would leak through the firewall and allow water to pool on the power distribution block causing the ignition system to remain energized even with the key out. It never engaged the starter however. Never found the leak.I ended up just spraying rattle can undercoat on the whole firewall. No more problems.
Or it could be aliens.
Bob
Old Apr 30, 2015 | 10:16 AM
tbirdsps's Avatar
tbirdsps
My Dad's 77 Ford Granada did that years ago. The next day a recall notice came in the mail. Something to do with the computer back then.
Old Apr 30, 2015 | 11:19 AM
antfarmer2's Avatar
antfarmer2
k
Well you live in casper so most likely a friendly goast
Old Apr 30, 2015 | 11:56 AM
davewhtt's Avatar
davewhtt
Did you see any crop circles??
Old Apr 30, 2015 | 12:09 PM
wydopnthrtl's Avatar
wydopnthrtl
Yeah baby... grab the steel and head out to take care of business! A real American folks
In my estimation it can only be one of two (mechanical) things.
1. The ignition switch is shorting out internally (unlikely and I've never seen one from a L98 vette) I've only dealt with the old GM style where this kind of thing could happen.
2. The car has a remote starter and you simply didn't know about it. (I've seen this before.. people are convinced they don't have one... but they actually do)
IMO.. if there is a short you need to find out asap. Could cause a fire.
Old Apr 30, 2015 | 12:12 PM
steve1657's Avatar
steve1657
Keep those ghosts up in Wyoming, little too close for comfort for me here in Northern Colorado !! Not many of us up this way, hope you get it figured out. Stay safe up there.
Old Apr 30, 2015 | 12:44 PM
starrman62's Avatar
starrman62
Sounds like you handled that properly, firearm first!
Old Apr 30, 2015 | 03:57 PM
ToniJ1960's Avatar
ToniJ1960
I had a 89 Continental left the window down once it rained, the power mirror for the door was clicking the next day my neighbour came and told me about it. I went out looked at it sure enough the mirror was trying to move but stuck all the way over. No key in the car.
It turned out the switch had got some water in it,and burned enough to carbonize the plastic or whatever so it was conducting as if the switch was closed. Had to replace that switch. Wonder if any switches could have something like this going on?
Probably a good idea to be prepared for the unexpected. One night I heard the dog barking a lot looked out my window saw 2 guy by my car doors open. I went outside without thinking luckily they were gone. Found the ignition cylinder or part of it in the seat and the stereo halfway out.
Cars not worth dying for but I was fearless.
Old May 1, 2015 | 11:32 AM
kbone077's Avatar
kbone077
The car was sitting outside and we did get a good bit of snow and rain a couple of days previous suicide.
Old May 1, 2015 | 11:33 AM
kbone077's Avatar
kbone077
Thanks for the comments everyone. I know this was a weird problem certainly something I never have seen before..I will certainly look into it with the information I have received unless it's an actual ghosts or aliens then I just have to deal with it on a as it happens basis..lol
To Started by itself
Old May 1, 2015 | 11:02 PM
suicidejockey
I would definitely start looking for water leaks. Check the grommets wherever anything passes thru the firewall. I know, easier said than done. One thing you might try is waiting until dark and putting a bright light inside the car and seeing if you see any light shining thru anywhere under the hood. Good luck. If it turns out to be aliens instead, get pix. You'll be RICH!!
Old May 3, 2015 | 09:37 PM
HillbillyBill's Avatar
HillbillyBill
around here all the aliens are from mexico
Old May 4, 2015 | 09:43 PM
DinoBob's Avatar
DinoBob
This seems impossible.
