ecm codes
Old Aug 15, 2002 | 04:58 AM
jtfrog's Avatar
jtfrog
Default ecm codes
I have an 86 vette. Do I have an OBD1 ? Can I get the codes out with out the use of a scan tool and if so how. My check engine light come on intermitinly only on the freeway.
Jtfrog
Old Aug 15, 2002 | 10:45 AM
Aaron71771's Avatar
Aaron71771
Default Re: ecm codes (jtfrog)
You can get any codes in your ECM by grounding the diagnostic terminal. Maybe someone can post a picture to show you what I am talking about. Basically the process goes like this.
-Use a paperclip to ground the terminal on the ALDL connector
-Turn the key to the ON position but don't start the car
-The check engine light will blink any codes
-It will blink once then pause then blink twice then pause. This is a code 12, meaning they system is in diagnostic mode. It will show this code 3 times.
-After the code 12 they system will show remaining codes stores. After all the codes are shown it will blink a code 12 again three times.
Old Aug 15, 2002 | 10:59 AM
jtfrog's Avatar
jtfrog
Thanks for the help
To ecm codes
