Max throttle.
Old May 15, 2015 | 10:48 AM
anlgreen's Avatar
anlgreen
4th Gear
Default Max throttle.
I want to run my C4 at the track soon. It's a factory C4 LT1. What I need to know is can I put the throttle on the floor, let the auto trans shift, and not worry about over revving the engine?
I always let the throttle up a bit to let it shift to avoid this!
Is the computer set up to keep the engine below redline if I want to weekend race?
Old May 15, 2015 | 01:18 PM
383vett's Avatar
383vett
It's a Corvette. You should be practicing full throttle runs on the way to work every day.
Old May 15, 2015 | 01:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Trans isn't computer controlled, but should be calibrated to shift before over rev anyway. IF it doesn't, the engine has a rev limiter set to about 5800 so there should be no need to be overly concerned about the engine over revving.
Old May 15, 2015 | 02:40 PM
aboatguy's Avatar
aboatguy
Old May 15, 2015 | 02:59 PM
tbirdsps's Avatar
tbirdsps
I found that on my 90 L98 the tach gets no where near to redline. The tranny shifts around 4800 rpm.
Old Jun 11, 2015 | 08:57 PM
krackenvette's Avatar
krackenvette
That is redline on an L98....
Old Jun 11, 2015 | 09:22 PM
Drew95's Avatar
Drew95
You're gonna start some sh*t with that one....
Tom vs. "Torque Monster" - Rematch.
Old Jun 11, 2015 | 09:44 PM
krackenvette
To Max throttle.
