open loop
Old May 25, 2015 | 09:47 PM
gman35's Avatar
gman35
Default open loop
After replacing full exhaust system with ceramic hooker long tubes with emission tubes. and leaving all the air pump stuff intact, minus the cats of course. My wife says she smells exhaust fumes, personally I can't smell them since I lost most of my sense of smell from my brain injury when I was ran over at work.
Does anyone know of a check that I could do to determine if I am going into closed loop?? I did put new connectors on the O2 sensor and installed a heated O2 sensor.. I did have a issue with the 12v switched feed to the sensor... but the o2 sensor is so high on the header tube that I questioned even needing a heated sensor. thanks for any help, Gary
Old May 25, 2015 | 10:03 PM
jv9999's Avatar
jv9999
Without cats it's going to smell like a pre-cat car. The best way to see what's going on is to scan it, but if it wasn't going into closed loop the CEL would come on.
Old May 25, 2015 | 10:09 PM
gman35's Avatar
gman35
Default Roger that
Roger that, and thanks for the reply.. it runs really good with the new exhaust system.. and no codes at all have come up since the install.. thought about installing the air line from the air pump to add some additional air to the exhaust,, or maybe a hi po cat?? thanks, gary
Old May 25, 2015 | 11:02 PM
Cliff Harris's Avatar
Cliff Harris
If you have a pre-1990 car (you didn't tell us the year), you can tell if it's in open or closed loop by shorting the A & B contacts together in the ALDL connector AFTER the engine is running. If it's in open loop mode the Service Engine Soon light will flash at 2-1/2 times a second. If it's in closed loop mode it will flash once per second.
Old May 26, 2015 | 08:20 AM
TA's Avatar
TA
I believe this works on a 91 also
Old May 27, 2015 | 12:42 PM
pkincy's Avatar
pkincy
Adding LTs without a tune and it will be running rich....particularly at idle. Simply take it in for a tune. However you will get unburned HC out the exhaust so that will always smell and is a dead giveaway to a car without cats, as the bumper fascia above the exhaust tips gets black.
Old May 27, 2015 | 04:26 PM
vader86's Avatar
vader86
The best way is to do the SES light trick above or drive it around with a scanner hooked up. The scanner will tell you when it drops back into open loop mode, which will probably only be at idle.
A tune will help, but it is not strictly necessary, nor is a heated O2 sensor.
To open loop
