Wheel help
May 28, 2015 | 06:47 PM
Wheel help
Does anyone know if you can fit a 20x10 wheel under a c4 with the right offset?
May 28, 2015 | 06:53 PM
Quote:
Originally Posted by
91vettedude
With the correct offset -yes. What do you anticipate for a tire size though? That might be a much more difficult issue. An appropriate sized tire might resemble a "rubber-band".
May 28, 2015 | 07:18 PM
WVZR-1
The tires are thin I don't know size till am, but only approximately 1 inch sidewall. Any idea of the offset I would need Thank you
May 28, 2015 | 07:32 PM
91vettedude
Are you trying to do the same wheel X 4 all the way around on maybe a '91? I assumed '91 from your user ID.
A 50mm might be considered ideal, a 55mm would do well also I'd think. Tire diameter in this particular case I'd think could be critical.
May 28, 2015 | 08:09 PM
Suckin' gas, haulin' ass.
Please, dear Lord, don't make a donk.
May 29, 2015 | 11:11 AM
Black89Z51
No I don't want that just want to fill the wheel wells tight
May 29, 2015 | 11:12 AM
WVZR-1
They are 20x9 up front and 20x10 in rear
May 29, 2015 | 02:49 PM
Actually they ar 19 275-35-19 and 245-40-19 any suggestions?
