Cumulative HP gain?
Old Jun 6, 2015 | 05:12 PM
unihusker's Avatar
unihusker
Default Cumulative HP gain?
Approximate cumulative HP gain?
Custom tune - around 15hp
Magnaflow cat-back exhaust - 10hp
K&N air filter - 3hp
Mid America Motorworks Mass-Airflow-Sensor Housing - 9hp(they claim)
So, added up...looking at about a 37hp net increase?
Old Jun 6, 2015 | 05:18 PM
DanielRicany's Avatar
DanielRicany
Eh. I'd say you're looking at about a 15 hp increase total.
Old Jun 6, 2015 | 10:34 PM
THE 383 admiral's Avatar
THE 383 admiral
What year. 94up a good tune with the cat back can make your total
The filter & housing. Negative.
Old Jun 6, 2015 | 10:37 PM
vader86's Avatar
vader86
MAF mod won't do jack. If you don't have more mods than these, the custom tune won't get you 15hp.
Old Jun 7, 2015 | 02:13 AM
unihusker's Avatar
unihusker
MAF claim comes from this article
http://www.superchevy.com/how-to/vem...injection.html
Old Jun 7, 2015 | 02:17 AM
unihusker's Avatar
unihusker
Old Jun 7, 2015 | 06:40 AM
Lloyd Smale's Avatar
Lloyd Smale
lets see. Ive got an air foil, coolant bypass, 160 degree thermostat, cat back exaust, k&n filter with opened up box, and a custom chip by hibach. I guess im putting down about 400 to the rear wheels truth be told id be impressed if I gained 10 rwhp.
Old Jun 7, 2015 | 08:10 AM
1stVetteFinally's Avatar
1stVetteFinally
@unihusker
all those little horsepower "upgrades" are not upgrades at all. Here's the thread where it was explained to me- https://www.corvetteforum.com/forums...or-92-lt1.html
It costs real money to get any noticeable HP increases from an LT1
Old Jun 7, 2015 | 02:12 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You can't "add up hp" like that. Doesn't work. First, the advertised gains claim UP TO xx HP. Meaning, on a highly modified motor, where the item in question has become a meaningful restriction, changing to their part may gain the number that they're claiming. On a STOCK or stockish motor, where the item in question is not a meaningful restriction, the power gains will be somewhere between nothing and meaningless.
You may have gained a few hp from what you've done, but certainly not 37 hp. Instead of guessing, why not put it on a chassis dyno to find out?
Old Jun 7, 2015 | 08:31 PM
unihusker's Avatar
unihusker
car is in the shop right now...I was just speculating before picking it up. I'll get the dyno results at that time.
Old Jun 8, 2015 | 05:23 AM
HlhnEast's Avatar
HlhnEast
I love threads like this! Good luck with that!
Old Jun 8, 2015 | 07:50 AM
markKlein's Avatar
markKlein
Did you get a baseline before the mods?
Old Jun 8, 2015 | 10:44 AM
vader86's Avatar
vader86
Haha, no.
Old Jun 8, 2015 | 03:29 PM
unihusker's Avatar
unihusker
it will be the first thing he does...
Old Jun 8, 2015 | 03:31 PM
unihusker's Avatar
unihusker
Haha, no.
??? not sure what you mean....from that article
Baseline
"Accustomed as we are to 600-, 800-, and even 1,000hp C5s and C6s, we were primed for disappointment when Anti-Venom proprietor Greg Lovell strapped our virgin '96 to the shop's Dynojet chassis dyno for its first pull. We were pleasantly surprised, then, when the car registered a respectable 263.3 horses and 291.5 lb-ft of torque at the rear wheels, not too far off what one might expect from an early automatic C5. After a backup test produced virtually identical numbers, we unlimbered the tools and got to work."
Old Jun 8, 2015 | 03:36 PM
unihusker's Avatar
unihusker
per this article...http://www.superchevy.com/how-to/vem...p/viewall.html
they're added up net gain the same way I'm speculating what my net increase end result will be. So why can't I apply using this method as well?
Old Jun 8, 2015 | 03:40 PM
don hall's Avatar
don hall
The cheapest way to gain HP is to lie about it, as some posts on this forum confirm.
To Cumulative HP gain?
Old Jun 8, 2015 | 03:48 PM
THE 383 admiral
Sorry as everyone is telling you. It does not work this way. Such as filter, 104 fuel, spark plugs, wires, dist, MAF housing & such.. NO gain mods. If this were the case. what I listed would make 30HP in your eye's or reading material. 1.6 rockers, Gears, Cam & tune and so on will result in the power add on's you are looking for.
Old Jun 8, 2015 | 06:07 PM
unihusker's Avatar
unihusker
Let's make something clear here...this is just a fun thread I started about possible HP gains with mods done. That's all...
Old Jun 8, 2015 | 07:01 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Baseline
I have no idea what your quote is supposed to convey here. The stock LT1 dyno'ed 263 hp. So what? Mine dyno'ed 279 stock...
They didn't "add up" the numbers, the dyno tested the car after the addition of each mod (w/o removing the previous mods).
Whatever they did, here is the bottom line: they spent ~$300.00 to get 13 hp. For that same amount of money, you could buy a cam, that would give you an honest 30hp or more. Diddle-f'ing around w/mass air meters, filters and mufflers is a waste of $$ if you're goal is HP.
