LT4 intake gasket done!
After days of reading posts on this forum and watching a few Youtube videos, I took the plunge. A couple of things I can add that nobody else touched on is to not try to remove the A.I.R. pipe from the exhaust manifold, if you break it, you cannot buy another one. Just loosen the bolt on the back of the passenger side cylinder head and the pipe bracket will slide up to give you plenty of room to remove the intake manifold. Also, I didn't want to open up my coolant system and risk getting an air pocket, so I just set the throttle body aside without disconnecting the coolant hoses from it. I used a piece of rope to tie it to the A/C lines--worked out perfectly.
I spent 2 hours just cleaning everything and making the intake look brand new. Total job took 6 hours over the course of 3 days. Had the car back up and running for the weekend and no more oil seepage out of the front and back of the intake. Best of all, I never had to even lay under the car--except when I changed the oil after the first test drive.
My advise--just take your time and label every connector and hose that you remove. It took more time to label everything than it did to remove them. Do not use brake clean on the LT4 intake--it doesn't play nice with the powdercoating--use Simple Green, small brushes, and towels.
Ciao
